It's definitely a puzzle... Speaking of which haven't I seen KeloGes making the same claim, system so good it produces sub-freezing vent temps? Plus haven't I seem KeloGes espousing the same refrigerant charging technique as Charlie? Charge ONLY to the level that gets a the best sub-freezing vent temp? Last edited by wwest; 04-06-2015 at 07:27 PM.. |
An explanation, maybe....
Due to the hysteresis span of the thermostatic switch plus the level of liquid refrigerant remaining(system cooling "coast" time) in the R/D at clutch off time the low IR you got might be perfectly normal. The time constant of the compressor on/off periods is fairly long, you might well measure a sub-freezing temperature, especially during the initial clutch off time ("coast" time) as long as the switch hysteresis causes the clutch circuit to remain off/open for and equal or slightly greater time with the evaporator above the freezing level. Result, the AVERAGE evaporator core temperature over the complete system cycle time is slightly ABOVE freezing. Hold the PR trigger on for an entire system cycle period, or even several, and then check the min/max readouts...
Fleabit peanut monkey
If the car has X units of moisture inside and eventually all freezes inside the evaporator, what is the amount that freezes it to the point of non-operation?
1981 911SC Targa |
so ok you think I have got nothing then go away back to your beer and someplace else Last edited by KelogGes; 04-06-2015 at 06:45 PM.. |
Banned
Will, I'm sure you are onto something about the core temp typically staying at a temperature slightly above freezing. I've never tried to determine that because the system has performed so well (nothing to trouble shoot, etc).
It would be interesting to see how much moisture is wicked into the cabin - no indication of visible moisture on the vents and such and the air inside the cabin feels crisp and fresh - the opposite of humid, in other words. |
The only recent example, recent being circa 1993-4, was in our 1992 Lexus LS400. Each instance involved driving up rising terrain, McDonald pass in Mt, I5 in northern Ca. In each the instance the evaporator airflow was practically non-existent by the time we realized the cabin was becoming uncomfortably warm. It only took a few minutes with the compressor off to return the system to normal operation. |
Banned
Banned
But, would you buy if she came a knockin' at yer door?!?!
French Import
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
You called BS on Ronnie's sub freezing numbers and by default, every thing he said in that post. Yet you asked zero questions about the scenario.
From my perspective that is a shooting from the hip, for spite, lie. Then I am degraded for my squillion post count and talking of or drinking beer. It ain't the AC talk that frosts me.
1981 911SC Targa |
I did ask her why and she said because she had no legs after riding in your car with the AC on after you drove her the long way home from the playground.
1981 911SC Targa |
Go read "scientific laws of Thermodynamics" Laws of thermodynamics - Wikipedia, the free encyclopedia en.wikipedia.org/wiki/Laws_of_thermodynamics Wikipedia The four laws of thermodynamics define fundamental physical quantities ..... to Entropy: Statistical Thermodynamics Based on Information, World Scientific, New . treaties on planet earth aplied to automotive A/C System I am done with you go sit in the corner some place else |
Back To The Topic of this Tread
Reversing The Gases Works Far better than Porsche's Engineers OEM Design THIS IS NOT BS My discovery works great, and I give it for free TRY IT YOU WILL LIKE IT!!! Believe it or don't |
Otherwise we must trust your memory since you agreed that you kept no records. |
Pictures came from the actual "reverse" trial?
Low side -5 PSI high side 140 PSI... I'm in the dark completely on this one, please explain.. ![]() Guages in focus for clarity.
Low side minus 5 PSI = ~22 degrees below zero, yet your reading was only just barely sub-freezing...??
How so, blockage to flow between the evaporator outlet and the compressor inlet? Oh, sub-freezing vent temperatures are still BS..??
Banned
I always keep the magnetic, Free Candy sign within arm's reach, dontcha' know!!! Last edited by Ronnie's.930; 04-07-2015 at 02:21 PM.. |
Banned
