Shaun @ Tru6's Avatar
100 to 108mm flange adapter
I've looked far and wide and haven't seen anyone make an adapter that would bolt onto a fine spline 100mm transmission flange making it a 108.
Has anyone seen this done, even as a 1-off?
Tru6 Restoration & Design
Old 04-29-2015, 09:37 AM
Walt Fricke's Avatar
Shaun
To make a bolt-on adapter you would need to run shorter axles. That would complicate this. Otherwise you would have do some machining and welding and more machining.
Old 04-29-2015, 09:12 PM
Thanks Walt, do you think the 8-10mm added thickness would need to shorten the axles? I guess that's the most important question.
Old 04-30-2015, 06:42 AM
KTL KTL is offline
Schleprock
KTL's Avatar
I agree the adapter would require the axles to be shorter. The adapter will take up some of the "plunge" depth that a CV joint has. If the axle bottoms out in its movement, it'll destroy itself in short order.
Get yourself a set of fine spine 108 flanges and adapt them this way (NOT) Custom Transmission Flange?
Kevin L
'86 Carrera "Larry"
Old 04-30-2015, 08:19 AM
KTL KTL is offline
Schleprock
KTL's Avatar
This is a good thread from the 914World site where Eric Shea @ PMB shows how he did a flange conversion and used SAW floating axles to establish his proper axle length
914World.com - The fastest growing online 914 community!
Kevin L
'86 Carrera "Larry"
Old 04-30-2015, 08:25 AM
Thanks Kevin, appreciate it. So it is ultimately just too much work I think.
Old 04-30-2015, 09:09 AM
Under the radar
Trackrash's Avatar
Somewhere in this forum I have seen examples of adapters. One was a ring welded on and re-drilled and another was just redrilled. I don't think this sounds like a good idea.
Can't you use later Carrera flanges?
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-30-2015, 10:22 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Later Carrera or Turbo flanges are sort of hard to come by. They usually stay with the trans, so a lone pair of them isn't all that common. That said, I know a guy here on the forum who has a set if you want me to send him your way Shaun?
Kevin L
'86 Carrera "Larry"
Old 04-30-2015, 10:27 AM
Thanks Kevin, yes, please!
Old 04-30-2015, 10:47 AM
gearhead
You can take G50 flanges and shorten them so that the sealing ring location is correct.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 04-30-2015, 11:29 AM
