Topless crazy
Planning on a drop in the near future (Probably at end of summer, trying to get everything lined up etc) and could use a helping hand (Very leery of tranny dis-connect and re-connections comfortable with everything else mostly.
Also: Be looking to rent/borrow engine stand/yoke too, let me know, much appreciated. |
Attleboro here
PM me your contact information. I have a few friends in the area who I can probably get to help as well.
(6) cars currently in my garage:1976 Porsche 912E #627 Ascot Green 1986 Ferrari Mondial 3.2 Coupe Brown/Tan 1986 Porsche 911 Carrera 3.2 Paint to Sample Brown/Brown 1985 RoW Mercedes 420SEC C126 Coupe Brown/Tan, 1978 Alfetta GTV with a TwinSpark, 1997 BMW Z3 1.9 Boston Green/Beige 5speed |
Topless crazy
ferrariguy - pm on the way
I have never done an engine drop but am willing to give you a hand if you need the help. I am about an hour drive from you. Just let me know.
Lou |
Topless crazy
LOU, I appreciate the offer- Where in mass are you? I'll see what happens the closer I get. Definitely could use a second set of hands though. sean
carrerarsr65
l
I live in Agawam ma just did a engine /tranny drop piece of cake 4 bolts undo shift coupler throttle clutch cable some misc hose done
Topless crazy
CARRERASR: You make it sound so easy, Feel like I'm already starting to hyperventilate. My biggest drawback is I'm in an outside storage/tent space its big 20x20 but no cement floor which is a problem. Damn that head stud!!!!!
Sean,
I am located in Chelmsford. Just let me know if you need a hand when the time comes. I too have an 83 sc. We can exchange info via pm.
Lou |
I'm about 1/2 hour away and dropped engine last spring.
Sounds like you will have a lot of hands available One good thing about living in an area with crappy weather, our maintenance season is much longer |
ck the host here there is how to drop engine
it is easy and fun, try timing yourself the second time around you can do it in 45 min, given you have a lift good luck
"IGNITION LEFT OF STEERING" Alex |
carrerarsr65
safetyfirst
try to get 2 sheets of 4x8 plywood, you heed to get the back of the car up about 34 inches at thr rear reflector and take off the rear bumper gives better clearance
![]() run jack stands on inner torsion tube |
