wwest's Avatar
Dave...
Don't remember...
Have you added the trinary pressure switch? No need to burden the alternator with the fan loads if the engine RPM does, is doing, the trick.
Plus extend the life of the cabin heat blower.
Old 04-02-2015, 10:13 AM
wwest's Avatar
Originally Posted by pmax View Post
And the total cost is .... ?
He says that he re-installed the stock factory system plus adding the factory type front condenser but with a makeshift fan.
Salvaged parts otherwise.
Likely under $500.
Old 04-02-2015, 10:42 AM
Originally Posted by wwest View Post
Dave...
Don't remember...
I bought the clamp on thermal switch, but not yet installed.
D
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 04-02-2015, 10:50 AM
wwest's Avatar
D
Did you measure the condenser inflow connecter temperature to determine the Approximate switch trip point?
Old 04-02-2015, 11:00 AM
My other ride is a C-130J
RNajarian's Avatar
[QUOTE]
Quote de RNajarian
My system is essentially from a 1983 SC. Salvaged parts from that car were Sanden compressor, rear condenser, a few refrigerant hoses. I got those for free. I needed to buy a new dryer (aftermarket Four Seasons ~$25)
I bought a used front condenser off eBay ( ~$100) and a couple used refrigerant hoses off eBay ( ~$75)
A few small hardware pieces (A/C O rings, mounting hardware etc.). ~$50
I added a front fan for the condenser with a relay, ~$50
So using salvaged hardware and buying a few missing pieces I spent less than $500.
I also bought a vacuum to clear out the system ( ~$100 Harbor Freight) and R134 (at the time $7 per small can)
I saved $$$ by having a good compressor, good rear condenser and a pre installed evaporator and Schrader Valve.
Of course I spent A LOT of time installing, reinstalling and adjusting the system.
I did not need to buy much, my "expense" was a lot of research and labor.
Again when hardware fails I will upgrade, but I see no reason to open up a good working system
Old 04-02-2015, 11:09 AM
