Senior Member
Jdub's Avatar
So you put a voltmeter in your Pcar? Please show me how.
I have recently seen the bouncing tach just one day, and off times smelled the evil sulfur of overcharge, but my grounds appear solid and readings of 12.5 up to 14.4 (at rest; at 2k rpm). I need to catch these spikes (if that is what is going on) via a gauge, so my questions - thank you for reading and replying!
So I am thinking I would like to remove the oil level gauge and go with a voltmeter there instead. Has anyone done this? For any placement of the gauge, what are the best locations to draw the readings - directly off the battery?
Many thanks for your input!
'78 Targa in Minerva Blue
Old 03-26-2015, 08:30 AM
Buy an AFR meter with a built in voltmeter display. Serves 2 functions at once - very useful...
Old 03-26-2015, 08:33 AM
Paper Member
You don't want the positive directly off the battery, otherwise your voltmeter will be on all the time. Find a switched positive.
Enemy of the State
Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it.
Old 03-26-2015, 08:34 AM
Is there an easily accessible switched wire from one of the other gauges that can be tapped?
1986 911 3.2 Cabriolet
"We all have a desire to create something that will show we were here. " Ferry Porsche
Old 03-26-2015, 08:35 AM
ROW '78 911 Targa
timmy2's Avatar
I just used a plug in digital unit in my lighter socket. It showed me all I needed to know before I replaced my VR.
Old 03-26-2015, 08:38 AM
I put in a couple of power outlets (cigarette lighter sized ones) inside the center console of my 911 SC. I wired it up to fuse box with a separate fuse - I hooked it up to have power when the car is on. I then purchased a volt meter that plugs into said adapter. This gives voltage as soon as the car ignition is turned on and when running the car - it also offers the option to unplug it and have two outlets to say, charge a phone and power a GPS.
You could just plug in the voltmeter to your stock cigarette lighter (if you have one) - if it fits properly.
YMMV
Wayne
1980 911 SC
1960 MGA 1600
Old 03-26-2015, 08:40 AM
KTL KTL is offline
Schleprock
KTL's Avatar
I would suggest a digital meter so you can watch the fluctuation of voltage more easily. Or make sure whatever analog gauge you use is not one with heavily damped needle movement. Reason I say this is because I have used the common VDO volt gauge that does a nice job of matching the other VDO gauges. But it's needle is REALLY slow to move and doesn't reveal the voltage fluctuation very well.
Kevin L
'86 Carrera "Larry"
Old 03-26-2015, 11:25 AM
I think with any gauge, even an analog with minimal dampening, it will be hard to catch small spikes.
That said, I have a voltmeter in my car, on a bracket that fits where the ashtray was. Bracket also holds my 12 year old XM radio module.
Chuck.H
'89 TurboLookTarga, 392k miles
Old 03-26-2015, 11:37 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Here is mine, after test driving the fist Gen Tesla. I was diggin on the Stereo it had:
Sorry about the bad pic.
'85 Carrera Targa
PCA/POC
Old 03-26-2015, 11:42 AM
I configured my passport 9500ix to show voltage as the default display preference -- plugs right into my cigarette lighter and does a good job of showing voltage fluctuations (1/10th of a volt) -- bit pricey for a voltmeter, but it performs other jobs for me quite well.
Others have had North Hollywood Speedometer add a voltmeter to the bottom of their tachometers . . .
Old 03-26-2015, 11:43 AM
Bandwidth AbUser
Jim Richards's Avatar
This is what I had North Hollywood Speedometer do to the tach on my old 73E:
Jim R.
Old 03-26-2015, 11:47 AM
pavegeno's Avatar
Send a message via Skype™ to pavegeno
Keep this permanently plugged into a receptacle I installed under the dash...working for years without a problem.
http://www.amazon.com/INNOVA-3721-Battery-Charging-Monitor/dp/B000EVWDU0/ref=sr_1_1?ie=UTF8&qid=1427398331&sr=8-1&keywords=innova+3721
Old 03-26-2015, 12:33 PM
Stutzdriver's Avatar
Here is mine before the console was reinstalled. I had the gauge in a box so I used what I had. Covered the bracket with some black leather I had laying around from another project.
I wired it into the fuel pump fuse so I can see if the DME relay ever fails, No DME workie, no fuel pump circuit energized, no volt meter workie (reads zero).
Jay Traner
1984 911 targa
1923 STuTZ 690 Touring
2014 VW CC 2.0T
2021 Subaru Forester (Mrs)
Old 03-26-2015, 01:34 PM
Every tutorial online says to connect the voltmeter to a wire that has power when the battery is off. Is that really recommended? I've got enough of a parasitic drain as it is.
Old 03-26-2015, 04:35 PM
Personally I would put it on a switched circuit. Like I said above I used the fuel pump fuse connection, hid the wire well and there is no evidence its there.
The gauge works fine when the fuel pump come on when starting and its an indicator if I ever have a DME relay failure.
Jay Traner
1984 911 targa
2014 VW CC 2.0T
Old 03-26-2015, 04:44 PM
vinny c's Avatar
Another NH Speedo
Old 03-26-2015, 05:34 PM
Vereeken's Avatar
Originally Posted by vinny c View Post
Another NH Speedo
That is simply well excecuted.....I wish we had that over here.
My dad always found an excuse why not to buy a Porsche, so I guess I am all out of excuses.
Old 03-27-2015, 06:44 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Easy enough, I sold a spare tach to a bloke down under, he had me ship the tach to North Hollywood, they did the mod and shipped it to him. Easy peasy!
BTW, NH will locate the meter where you want it I have had 2 done, one for the 75 at the 6:00 position and for the 84 at the 3:00 position. The mod that I see every time I drive the car, 5 star mod, and the eliminated the stupid mini- van shift light. They can also make the red line mark wherever tou would like it.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 03-27-2015, 07:43 AM
TheSt|G's Avatar
What was the cost of the voltmeter retro from NH? I certainly wouldn't mind ditching the pointless shift light.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 03-27-2015, 07:54 AM
get something like this and put it anywhere......if you can afford it!!
Mini DC 0 1 30V LED Panel Voltage Meter 3 Digital Display Voltmeter Motorcycle | eBay
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 03-27-2015, 08:32 AM
