MSD install help /1969 911t
Where does the Red wire go? Seems a long way to run it to the ignition key.
Where do the Heavy Red and Heavy Black go? Even longer to the batteries.
Thank you in advance.
Old 04-04-2015, 03:04 PM
The heavy black wire just needs to be grounded to the body. I ran the heavy red wire to the hot lead on the starter since it comes right from the battery. The small red wire I ran to the rear fuse box to a connection that was hot.
Tom Feeney
1970 911 T
1973 911 T
Looking for engine 6103643
Old 04-04-2015, 03:55 PM
L57 MSD mod
Old 04-04-2015, 03:59 PM
thank you
thank you for the assistance!
Old 04-06-2015, 12:49 PM
You will need a tach adapter so that your tach will work.
Tom Feeney
1970 911 T
1973 911 T
Old 04-06-2015, 01:03 PM
confused again
From what I've read (and stolen for this reply), from 1964 to sometime in 1971, the VDO tachs were driven off a 24v, square wave signal, direct from the + terminal of the coil. This resulted in too much volts to the tach. In 1969 Porsche introduced the CDI but didn't change the VDO tachs until late-71 so Porsche created the "intermediate unit", basically another coil to reduce the volts to the tach, to something like 11v. Hopefully, I've plagiarized that correctly.
When I got the MSD pack, instructions say the MSD Tach Output wire produces a 12v square wave signal with a 22.5deg duty cycle. Further on, MSD instructions say if you have a ballast resistor in-line with the coil wiring, it is recommended to bypass it.
So, to have a happy tach, do I need the "intermediate unit"?
I've read the "intermediate unit" called a "ballast unit", a "resistive divider". Mine is Bosch #0 227 990 001 / Porsche #901 602 601 00. A couple of pictures:
Old 04-06-2015, 01:55 PM
Here's my understanding. The old coils used to run at 9v or so, there was a resistor in the back to drop the voltage. A relay triggered by the yellow wire from the starter would bypass the resistor and send 12v to the coil while the starter was cranking.
If you use a newer coil, Bosch blue or other, these work on 12v so remove the relay and resistor and dead end the yellow wire. Install the MSD as per instructions and use a Tach adapter. The diagram I posted is for a 68 but you should be able to correlate it to a 69.
Old 04-06-2015, 03:50 PM
10-4 10-4
Got the Master Blaster blue coil with the MSD parts.
Thank you for the input!
BTW - I printed your schematic on big paper and it now hangs proudly on the wall of the office / garage.
Old 04-06-2015, 04:03 PM
Under the radar
Trackrash's Avatar
Let us know if your tach works just by removing the intermediate unit. That's been an area of debate.
It's my understanding that the intermediate unit was used in conjunction with the CDI unit so the older style (points trigger) tach could continue to be used.
BTW, I am assuming that your 69 had a CDI unit originally.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-06-2015, 04:12 PM
subscribed! I'll be doing this shortly on my '71 2.2T w/ webers
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end.
http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html
Old 04-07-2015, 07:35 AM
El Duderino
tirwin's Avatar
I'm late to this party and things may be somewhat different with an early 911, but generally it is a good idea to run the red wire directly to the starter with a dedicated fuse. I think the MSD rule of thumb sizing is 1 amp for every 1k of RPM so 10A should be plenty.
Old 04-07-2015, 08:59 AM
