7783911's Avatar
Dropping Idle
I have been having an issue with my idle speed when the car is just started and warming up..
Cold start is instant and idle is fine...however, until 100% warmed up...when you lift off the gas (or clutch in) the idle drops very quickly to 350 and bounces back up or when really cold, it drops and stalls before it can bounce back up
Once warmed up...there is still a rapid drop but it only drops to 650 and instantly recovers to normal idle speed of 900
I am not sure where to start my investigation
I have a 1983 SC engine (77 Targa) implant. The car did sit in storage for many years before I purchased but its been almost 1 year and other then this issue (and somewhat suspect mileage) it is tight and responsive
any thoughts?
bc
Old 04-05-2015, 09:49 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Check for vacuum leaks, a cracked rubber hose will expand as it the engine bay heats up helping to seal up the suspect leak. Open the oil cap cold and hot see if there is a difference.
After that I would check your fuel filter.
BTW, Welcome a board! She is Purty
'85 Carrera Targa
PCA/POC
Old 04-05-2015, 12:14 PM
1983 SC engine.........
BC,
You did not specify if the '83 SC engine still has the OEM CIS on it. If it does, you need to know the following:
Fuel pressures (control and system)
Absence of any significant source of vacuum leak
Fuel mixture (do not tinker yet).
What's the WUR number? What's the heater resistance (Ohms) at room temp. Is the engine a USA/ CAN or Row model? These are some of the basic information we need to know before we could give a meaningful advise. Keep us posted.
Tony
Old 04-05-2015, 12:36 PM
El Duderino
tirwin's Avatar
Welcome!
+1 to what Draco said.
Your mixture is too lean. Check for a vac leak.
There are two mistakes people tend to do when encountering this problem. The first is they jump straight to adjusting the mixture. That is the LAST thing you do. The second is they replace the fuel accumulator. Usually doesn't help and it's just a guess instead of actual troubleshooting.
Read this: CIS Troubleshooting for Dummies
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 04-05-2015, 12:43 PM
7783911's Avatar
It has the K Jetronic Injection...
I have previously suspected a vacuum leak only because I did the oil cap on/off test and there was no change in idle as a result..
I may take it somewhere for a proper leak test and that makes a logical first stop in the trouble shooting..thanks
Old 04-05-2015, 02:01 PM
DRACO A5OG's Avatar
If you have a cigar, you can locate your leak 😁
Old 04-05-2015, 02:54 PM
nene's Avatar
Draco,
You are going to turn us all into smokers....buy it will be worth it, as I still need to do this!!
Old 04-05-2015, 03:32 PM
DRACO A5OG's Avatar
Guilty, I am a Bad Influence
'85 Carrera Targa
PCA/POC
Old 04-05-2015, 03:34 PM
T77911S's Avatar
its too rich.
when it is rich if you blip the throttle and the RPMs will drop then come back up.
i have not seen it do this when lean.
this is how i set the mixture by ear. set it rich until the RPM;s drop then back it off to where thye dont.
this could be a sign the WUR is not heating up due to bad WUR or no power to it
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 04-06-2015, 06:44 AM
My 82SC would do this and stall at stop signs. It was sucking unmetered air from numerous holes in the CIS Pope's hat (surprised it even ran) and the vac line from the throttle body to the WUR was very loose.
Old 04-06-2015, 02:41 PM
jwakil's Avatar
Seems we have the same problem. (See my very recent post). Unfortunately I can't do the oil cap test on my 930 as it is vented, unlike the SC, but other things should be similar. Let me know what you find and I'll do the same.
82 - Austin Mini 998
78 Mini 1275cc -totaled
83SC Euro w/77 3.0 Carerra Eng.--sold
Several other daily drivers not worth mentioning...
Old 04-06-2015, 02:50 PM
7783911's Avatar
I contacted my Porsche guru (ex mechanic from Porsche Race team in NA) and he will take a look, he believes (as T77911S suggests) that this is a mixture issue but he wants to see the car himself. If the weather is good..i am for a drive tomorrow..but without the Targa top since its in NJ being rebuilt as we speak
Old 04-06-2015, 05:58 PM
T77911S's Avatar
he sounds like a doctor.
doctor, i have a headache. " you need to come in so i can get paid to give you an asprin".
RACE CAR:: sold
Old 04-07-2015, 03:42 AM
jwakil's Avatar
A mixture issue would also be evident when engine is warm, and mixture is set it when engine is warm. It does not explain why we have problems only in the warm up stage. If you mess with your mixture, it might not run as well when warm.
Old 04-07-2015, 12:18 PM
7783911's Avatar
no vacuum leak....(he also states removing oil cap wont work on older models)...the main culprit is the lack of back pressure from my race exhaust...he adjusted the rate at which the rpm drops via the decel valve and its running perfect now...
next task...slow windows..tried graphite powder in runners..didn't really help...looks like doors need to come apart for a thorough look
Old 04-07-2015, 12:33 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by T77911S View Post
its too rich.
I have to think this is very possible.
I would remove vacuum leaks first as he has some. Once sealed and if rich, symptoms may get worse. That would be a good thing - meaning closer to the answer.
1981 911SC Targa
Old 04-07-2015, 12:35 PM
Bob Kontak's Avatar
Yes - can't remember the cut-off year but it was close to the start of the SC.
Slow windows.....Yes, pull the door panel. It's slow going on the 911 with all the pieces/parts. Find the terminal numbers on the back of the window switch and associate with the wire colors and fully remove the switch for ease of access.
Find the big arced gear that moves the regulator and put grease on some of the teeth. Best to reinstall the switch after the panel is out of the way so you can move the big gear to where you can apply the grease to three of four sections. Then test. I don't think you need a bunch of grease.
1981 911SC Targa
Old 04-07-2015, 12:44 PM
Tags
83 sc engine idle
