Hi
Targa Me's Avatar
Gearbox Mounts
Hello Everyone
You're looking at a 1984, 915 gearbox mounts.
You will see a gap in there. Do I have these things mounted upside down? Let me know your thoughts.
Thanks.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 04-04-2015, 08:46 AM
The bolts are tight but there is always a gap
Bruce
Old 04-04-2015, 09:31 AM
Under the radar
Trackrash's Avatar
If the clutch engages smoothly when starting out, you are good.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-04-2015, 02:01 PM
Member 911 Anonymous
DRACO A5OG's Avatar
You got it correctly Brother L
Some have grounded down the metal tube around 3MM to take up the gap, but those are track guys.
J
'85 Carrera Targa
PCA/POC
Old 04-04-2015, 02:09 PM
nene's Avatar
Guys, I recently replaced all of my 86's mounts due to the Shifter "Kicking" feel when letting up on the gas. Well, the mounts helped, but did not eliminate the kicking feel and I believe it is due to this gap. I will probably end up putting an extra washer there to off-set this gap.
Old 04-04-2015, 05:11 PM
Under the radar
Trackrash's Avatar
I shimmed mine with a thick washer, so the rubber was tight. Helped fix my clutch shutter when starting out.
Gordon
Old 04-04-2015, 05:52 PM
Hi
Targa Me's Avatar
Thanks for the input guys !
Old 04-05-2015, 07:27 AM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
Have you looked at the motor mounts at all? Obviously they are the other half of the equation in alleviating awkward shift behavior.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 04-05-2015, 07:43 AM
Hi
Targa Me's Avatar
My car doesn't have an awkward shift problem. I just simply noticed the gap in the trans mounts.
Old 04-05-2015, 11:14 AM
Get solid mounts for at transmission location
Old 04-05-2015, 11:19 AM
