-   -   Tracked down both 8" and 9" Fuchs, what would you pick? (http://forums.pelicanparts.com/porsche-911-technical-forum/859706-tracked-down-both-8-9-fuchs-what-would-you-pick.html)
Bill Verburg 04-21-2015 09:05 AM
Originally Posted by Shaun 84 Targa (Post 8587289)
245s fit on 8s perfectly fine.
They may fit but for maximum performance potential you want them on 9s
Bill Verburg 04-21-2015 09:09 AM
Originally Posted by daleflesburg (Post 8587359)
I am using 205 55 16s on 8 inch rims and 225 50 16s on 9 inch rims. I personally like the look of a wheel rim that is as wide as the tire, and they handle just fine.
http://forums.pelicanparts.com/uploa...1429628865.jpg
for 8's and maximum performance potential you do want 225/50
for 205/55x16 you would want 7.5, but since Fuchs never made a 7.5, 7 will do fine, 8 is outside the tire manufacturers spec range.
Racerbvd 04-21-2015 09:11 AM
Thank you Bill for pointing out the actual true about what tire sizes were designed for what rim width/ You are absolutely correct, and people tend to ignore the fact that the side walls play A big part in not only handling, but safety, and stretching buy putting on a rim to wide or bulging, by using a rim to narrow, while some think it looks cool, is not the proper or size and not designed for most of our styles of driving.
I have both 8s &9s, currently running 7&8X16s with 205/50/16s & 225/50/16s, this choice was based on a couple of things, one being tires available at the time (needed then in a day) the other, we get a lot of rainy weather in FL, and I switch back & forth with daily drivers and the 225s on 8 are less likely to hydroplane if I get caught in the rain.
http://forums.pelicanparts.com/uploa...1429632676.jpg
Das Schnell Ei 04-21-2015 09:59 AM
8" seems like extra wheel for no reason with a 225 on the front no?
