jamesjedi's Avatar
3.6 Oil Coolers
Hoping for some help. I may be getting this oil cooler. I am concerned that it may be too small. It measures 23x5.5x2. It looks like an older B&B. Any thoughts wold be appreciated. Thanks.
Old 03-24-2015, 05:31 AM
Bill Verburg's Avatar
It does sort of look like a B&B
I have a B&B in my Ruf bumper, it's a perfect fit and is the only cooler I run.
5 1/2 X 2 1/4 X 20
It has worked great for street use since 1994 w/ both 3.6 and 3.8. You would want a larger one or an additional cooler or 2 in the fenders for track use.
I have 2 huge Setrabs in my 993 track car w/ great gobs of unrestricted air funneled to them, they work great but it does warm a bit on really hot days
Bill Verburg
Old 03-24-2015, 01:46 PM
jamesjedi's Avatar
Thanks Bill. It looks like it may be on the small side. What about combining it with a fender cooler?
Old 03-24-2015, 01:49 PM
RETIRED
Joe Bob's Avatar
I use a BAT INC. They are on the web. I have an extra set of mounts if you need them.
2012 ML350 3.0 Turbo Diesel
Old 03-24-2015, 05:44 PM
jamesjedi's Avatar
Joe Bob,
Which set of mounts do you have? Thanks.
Old 03-25-2015, 04:37 AM
As long as you have a functioning T/P valve you can always add another cooler in the fenders or just use 2x fender mounts like Elephant sells
A B&B will have tabs at the top for mounting and a drain plug in the bottom(at least mine does, if those are missing you may have a Mazda cooler which has I/O ports which are too small
Bill Verburg
Old 03-25-2015, 05:09 AM
Eng-o-neer
Tremelune's Avatar
What will you be using the car for? Where do you live? If street driving, I would see if you could put a fan or two on there if you're stuck in traffic or at a light in the summer. I wonder if a fender cooler and some enlarged bumper inlets would be enough.
Old 03-25-2015, 05:15 AM
jamesjedi's Avatar
Already have large inlet. Hopefully it will vintage race....one day.
Old 03-25-2015, 05:48 AM
Diss Member
Quicksilver's Avatar
The Mazda coolers are a great bargain BUT you must have a real ace welder to put larger fittings on it.
Not sure why this isn't much more popular.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 03-25-2015, 07:28 AM
I used similar-sized B&B cooler on my SC with 3.6 transplant, with SPAL fans and 190-degree thermo-switch. I have experienced 185-215 oil temps normal driving year-round. The fans rarely run, only when sitting in traffic on hot Summer day.
No track time yet......coming soon I hope.
[IMG][/IMG]
Old 03-25-2015, 09:52 AM
KTL KTL is offline
Schleprock
KTL's Avatar
That looks like a good center cooler candidate. Be sure to have some kind of history on its use, or else pay to have it ultrasonically cleaned. You don't want a cooler that's been contaminated with crud that will slowly release it to your engine and mess up your bearings.
Also take a look thru the cooling fins. Old coolers get clogged with dirt & tiny rocks & bits of tire rubber & bugs. If you back-blow it with compressed air, you'd be shocked how much crap it will spit out (and not spit out).
Kevin L
'86 Carrera "Larry"
Old 03-25-2015, 09:55 AM
jamesjedi's Avatar
Will definitely do a ultrasonic clean. If too small (roughly 253 inches squared), the cooling volume could dramatically increased with a moderately sized fender cooler. This addition would give more surface area and oil volume than a Setrab 172.
Thanks to all who contributed, it is really appreciated.
Old 03-25-2015, 01:26 PM
jamesjedi's Avatar
Does not look like Mazda, not sure though. The Mazda coolers that I found online have 8 rows. This one has ten.
PDtweeksthat is very nice ductwork and fan, neatly done.
Old 03-25-2015, 01:29 PM
RETIRED
Joe Bob's Avatar
http://97.74.32.155/files/cool$.pdf
Look here.....
Old 03-25-2015, 05:15 PM
jamesjedi's Avatar
I traded the cooler for some parts, it is now in my garage. I should have posted a picture of the mounting tabs;
Old 04-11-2015, 09:19 AM
