porschetub's Avatar
Ehaust rocker cover leakage???
Fitted left side cover after valve reset,nice clean surface and new gasket,torqued correctly and it leaks without the engine even running,is it mandatory to resurface these magnesium covers because they warp?
Have read this is an issue with them,the PO had very thick gaskets and sealer on them
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 04-10-2015, 12:36 PM
Time for new ones
Old 04-10-2015, 01:25 PM
Free minder
Aurel's Avatar
Replace with turbo valve covers. The ribs prevent wrapping. Well documented upgrade.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 04-10-2015, 03:41 PM
porschetub's Avatar
Not what I was asking really
Old 04-11-2015, 01:07 AM
You could do that, but a better option is to fit turbo lower valve covers.
Old 04-11-2015, 04:08 AM
ROW '78 911 Targa
timmy2's Avatar
A piece of glass made for flattening and sandpaper will square up the cover.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 04-11-2015, 09:41 AM
76 911S Targa
Or you can do what I did. Get the thick silicone valve cover gaskets from Pelican. No leaks.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 04-11-2015, 11:02 AM
joefrantz's Avatar
Magnesium covers often need to be flattened. The best method is judicious sanding on a fixed base belt sander with a very fine grit belt. Depending on severity you can also sand them by hand against a reliably flat surface. Plate glass is often suggested -- hopefully a nice thick piece. I used a sheet of 3/4 inch Melamine surfaced shelf board.
Gaskets are also important. The most popular type seem to be the ones with a silicon bead around the sealing surfaces. Another option is the red solid silicone type that are re-useable, but also somewhat fragile when hot.
Torque and tightening pattern are probably the most important variable. I think that most problems with magnesium covers have come from over tightening and/or not using the correct center-out, upper-lower alternating pattern.
I use the red silicone gaskets, and they will take very little torque. I put my finger on the edge of the gasket at each stud. I tighten until I feel the gasket bulge about 1/16 inch and stop. I would estimate it at no more the 2 ft. lbs. I’ve never had a leak or even any seepage.
Wayne’s engine book recommends 6 ft. lbs. pounds for the standard type gaskets, and I’m pretty sure that would include the silicon bead type.
As for the Turbo type valve covers – yes they're the popular solution, but I think they're a trade-off. They’re less fussy than the mag covers, but a full set of aluminum covers will add 3+ pounds to your engine weight. In my case, I knocked three pounds off of my 3.0 liter by replacing the turbo type covers with magnesium.
Joe Frantz
73 911 T
Old 04-11-2015, 12:03 PM
porschetub's Avatar
Thank you ,thats an answer in detail pretty much what I was after,pulled that cover today and found there was a chip of paint on the sealing surface around where the leak was,makes sense as the gaskets aren't really that thick,have an old mirror so will glue some sandpaper on there and see how I go,will report back,cheers.
Old 04-12-2015, 12:33 AM
