Franks89-911's Avatar
Need advice pls - replacing stereo in 89 911 3.2L Targa with 'enhanced' factory sys.
Hi all,
I have removed the CD-2 original unit without apparent incident or damage to self or my Black Beauty. HOWEVER - I have now found to my dismay, a 6-pin white connector, a long pin connector which I believe to be the antenna, and an 8-pin DIN style connector for a "preamp" which I assume then feeds amplified sound to the speakers via the preamp thingie below the passenger seat.
How in the world am I going to wire this car up to an aftermarket head unit? The sticker on the top of the CD-2 unit is of no guidance at least as to the speaker wires which are I suspect imbedded in the 8-pin DIN. It tells me what the white connector wires are, but that's it. Will I have to rewire this entire car? I had to do this on a 1990 Nissan Maxima once because of the weirdo Bose system it had in there, and it was a pain in the tuckus. But at least the Maxima gave me space to work with, the 911 has half the space.
And from you purists out there - I sure don't like the idea of cutting wires etc. on my Black Beauty just to put a silly radio in; would you just get the original head unit repaired? Any idea who does that in the Atlanta GA area?
Thanks,
Frank
Old 04-22-2015, 09:00 PM
RyanG's Avatar
Crutchfield and probably many other car stereo shops sell kits to adapt aftermarket stereos to the stock wiring.
Current ride: 2004 Mitsubishi Shogun Sport
Back in the US: 1979 911 SC (closer to completion), 2011 H-D XR1200X (storage), 2005 BMW R1200GS (in transit).
Past (too many to list them all): 2011 BMW X5 35d, 2006 Subaru WRX, 1987 Porsche 951, 2007 Mustang Cobra, 2004 Mustang GT, 1976 Toyota FJ-40, 2001 Buell M2
Old 04-22-2015, 09:07 PM
jbrown's Avatar
You will not find any adapter for that yr car to wire an aftermarket radio to it. It is not that hard. Obviously your powers, ground and power antenna lead are in the white plug. The system is amplified. In that harness, which is called a din cable are your signal leads to the amp and the amp turn on wire.
I have not installed one in a while so I don't remember schematics of that din cable but a qualified high end audio shop would be able to figure that out in 5 min.
By the way your 90 maxima is a piece of cake to install a radio with a bose system. Like RyanG said thay make a harness that is about $15.00 and it turns the bose amp on so you can use it.
Your not driving a $5.00 car go to a professional and get the right job done.
I own a high end audio shop in NY and I would install that radio for less than $100.00. I am sure in your area in would be similiar... John
83 sc cab turbo widebody. 3.5 liter supertec motor, B&B headers, EFI electromotive TecGT, TurboKraft GT35R billet turbo, 964 cams, WM inj, Bell full bay intercooler, Short bell housing turbo 4 speed tranny, roll bar, hargett shifter,
Old 04-23-2015, 04:59 AM
tailwind22's Avatar
Go to swstereo.com for contact info and speak to the owner Stephan. He can make you a custom adapter harness so not wires need to be cut. He can also assist in discussing options to replace the amp and not disturb wiring. He worked with me and I put a new Blaupunkt Toronto head unit, Punch amp and new speakers in my 89 without cutting original wiring or replacing speaker covers. I of course saved the original radio and amp so the car could be brought back to original some day.
73 914-6 GT tribute, 2.7L twin plug
23 911 w/aero kit
07 GT3 RS Pumpkin
Old 04-23-2015, 06:17 AM
RyanG's Avatar
That surprises me that companies like Scosche aren't already making an adapter harness. I ordered one from Crutchfield years ago that made installing a Blaupunkt aftermarket stereo in the '87 944 I used to own really easy.
Old 04-23-2015, 06:28 AM
jbrown's Avatar
Way to go. I did not know there was a company that makes the harness.
Schosche will not have harnesses for older Porsches anymore. There is not enough demand to make those anymore.
Old 04-23-2015, 09:13 AM
Thanks all. Stephan is my next stop.
Old 04-23-2015, 09:37 AM
Are you interested in selling the CD-2? If so, please PM me. Thanks!
Old 04-23-2015, 04:49 PM
toddadale's Avatar
I have out of mine 1989 3.2 the Blaupunkt BQA your welcome to it for 50 bucks to ship in the USA.
If everything seems under control, you're just not going fast enough.
Mario Andretti
Old 04-23-2015, 05:02 PM
toddadale's Avatar
HERE'S A PHOTO OF IT... I HAVE THE SAME CAR A 89 3.2 TARGA PM me if you want it
Mario Andretti
Old 04-23-2015, 05:06 PM
