Jtt84911's Avatar
Updated ATC Style Fuse Panel Owners
Hi Pelicans
If you've updated your 911 fuse panel via Fred Cook's design or other sources....did you also update the small 3-fuse block in the engine bay???
Here's what I did. It was easy.... and very inexpensive
Bought this small 4-fuse "mini panel" on eBay for $8.00! as you see it fits nicely on relay panel (drill and use small sheet metal screw) and if you mount it where I did.....YES you can put the plastic panel cover back without issues.
Here's the link to where I purchased it.
4 Way Fuse Blade Holder Box Block Car Vehicle Automotive Circuit 4 Fuse US | eBay
Best Wishes....
JT
Old 04-12-2015, 06:26 PM
Vintage Owner
Jack Stands's Avatar
Great little update! Makes sense to update all the fuses and not leave a few old ceramic fuses in the circuits.
Like the fact that the cover still fits like the original design.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 04-12-2015, 06:39 PM
Jtt84911's Avatar
Thanks. That was my thinking as well. After the cost and effort to replace the main panel... no brainer to do the rear as well. And compared the main panel....this job this was nothing.
Made a little 2 to 3 connector for the power side.... (similar to the one Fred supplies) added the 3 female spade connectors for the 3 circuits + some heat shrink wrap for all.....and that's about it.
It's literally like an hour job.
JT
Old 04-12-2015, 07:02 PM
Wow that looks really good, nice find
Old 04-13-2015, 06:46 AM
Nice job!
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 04-13-2015, 07:01 AM
Signal light fuse
Old 04-13-2015, 11:08 AM
There's always the el-cheapo 5-min. $5 solution. . . .
1982 911SC Wine Red Metallic
OMG I love this car!
Old 04-13-2015, 04:36 PM
For those who are doing the Fred Cook version, he offers a fuse panel for the rear as well. I just installed mine the other day.
1986 911 3.2 Cabriolet
"We all have a desire to create something that will show we were here. " Ferry Porsche
Old 04-13-2015, 07:38 PM
I will be doing that soon...just finished rewiring the front end. Nice solution.
Old 04-13-2015, 07:39 PM
Jtt84911's Avatar
Algernon
That looks good as well. Like the terminal screws. I probably would've used it myself if I found that block before the one I bought. Looks like the plastic cover would fit over it as well in that location??
BTW- I didn't mention it in my first post....but yes...that's an extra unused 4th fuse slot. Didn't plan to wire it for anything.....will use it as spare fuse holder.
JT
Old 04-13-2015, 10:32 PM
More expensive and more elaborate, I installed a Painless Cirkit relay setup:
CirKit Boss Auxiliary Fuse Block/7 Circuits/WeatherproofDetails | Painless Performance
Basically, heavy power feed from the starter, relay trigger from the red/white wire, then you have 3 always hot and 4 triggered circuits with fuses.
I'm running my Megasquirt/MSD (x2)/O2/defog/injectors/spotlight with mine, makes for a tidy setup. If you're careful, you can squeeze it in where the OP mounted his fuse block.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 04-14-2015, 07:06 AM
Originally Posted by Jtt84911 View Post
Algernon
Yes, the cover fits over just as before. nice thing about these blocks is that you still use the Porsche wire ends, straight into the blocks without any soldering or extra connectors that might give problems later. Less connections is always better - I did the same on the front, see my 'Cheap and easy ATO fuse block installation'
Old 04-14-2015, 03:39 PM
Algernon, shouldn't the 5 amp be in the bottom slot?
I relocated the fuse block so the cover would clear.
[IMG]Untitled[/IMG]
After removing the block I found it had previously been repaired.
[IMG] [/IMG]
Old 04-14-2015, 05:37 PM
fred cook's Avatar
Fuse Panels Front and Rear
Just in case anyone is curious, here is a picture of a pair of my fuse panels. The front is the deluxe version w/headlight relays. The rear (small) panel has 4 fuse positions so there will be a spare for future use. I have one of these in my SC and the spare came in handy when I was wiring up the twin plug Electromotive XDi iginition.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 04-14-2015, 08:56 PM
Jtt84911's Avatar
Hi Fred,
For the record everyone.......I have one of Fred's panels up front in my 84Targa.
Well made and good installation instructions as well. Lots of posts and happy customers for those considering the main panel upgrade!!
JT
Old 04-14-2015, 10:41 PM
QUOTE=gerber28;8577102]Algernon, shouldn't the 5 amp be in the bottom slot?
Yikes, you are right! No wonder I have no heat in the cab!
thanks,
Algernon
Old 04-15-2015, 11:35 AM
Send a message via AIM to Hcarraro Send a message via Yahoo to Hcarraro
Subscribed
Henry
Old 04-23-2015, 05:39 PM
