Helios59's Avatar
Clock Question: Temperature
So here's one I haven't seen answered before.
My clock works just fine, but only if the air temperature stays above 45 F or so. Below that it stops.
What the heck is going on here?
TIA
...and here's a photo because we all like that.
Ray
1986 Turbo-Look Cab
White Gold/Burgundy
Old 04-16-2015, 08:15 AM
ganun's Avatar
Gee, the clock is one of those things that made the top of the list of a recent "poll" here on the forum of "Things that you are amazed at that still work on your car" .
On my 87 it hold perfect time, ...
I would venture to say that its always getting power, if not check the fuses..... if it is, it must be something in the clock.
You can pull it out, check for power when its cold out. Which should be OK.
If you`re brave try opening up the can, and take a look but best advice is to send it to North Hollywood speedo.
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 04-16-2015, 08:47 AM
In my 1985, the 30 year old capacitors started to go - as expected. They dry out. It is a simple fix if you have a soldering iron. My guess is that your caps are on their way.
Here is a nice thread:
VDO Clock Crystal Info?
The other thing is that solder joints can crack and create opens in the circuitry. Again, you would nee a soldering iron to reflow the solder. I would recommend changing the caps if youa re in there.
Old 04-16-2015, 09:04 AM
Dave Colangelo's Avatar
Reflowing the solder may help as well replacing come of the old caps. You can oder them cheap from a place like Digikey.com (or the like there of). The other thing that could be an issue is the crystal but Im not sure how to actually replace those or test them.
Depending on where you are in MD (if its close ish to Philly) I have a soldering iron and other electrical test stuff you are welcome to have access too if you want to make the drive. Just make sure you get here on time
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 04-16-2015, 02:20 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Clock.
Replace these.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 04-16-2015, 03:26 PM
