Engine Bay Connector ID
This has always been tucked in the back, driver's side. Any ideas?
Thanks!
Old 03-08-2015, 10:34 AM
pete3799's Avatar
Have you got a plug like that on your warm-up regulator?
If not.......that's it.
Pete
79 911SC RoW
Old 03-08-2015, 10:40 AM
The warmup regulator is in your photo, center left edge, with the 11-12mm nut holding the fuel connection. To the left of the #1 intake runner shown.
Old 03-08-2015, 11:04 AM
Looks like my WUR already has a connector attached. This must be for something else?
Old 03-08-2015, 12:35 PM
ROW '78 911 Targa
timmy2's Avatar
Pull back the rubber boot to see what the colors of the wires are. Then post them and I can tell you where there are supposed to go.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 03-08-2015, 01:05 PM
Thanks, Tim. Black/yellow.
Old 03-08-2015, 01:29 PM
CSV plug........
Len,
Check the backside of your engine right below the throttle body. There should be an electrical plug/connector for the CSV (cold start valve). Keep us posted.
Tony
Old 03-08-2015, 04:45 PM
That's strange; had the engine out for a repaint, can't believe the shop didn't reconnect this! Engine's back in, can I reach the connector?
Old 03-08-2015, 06:01 PM
ROW '78 911 Targa
timmy2's Avatar
Reaching it will be a challenge. A mirror and flashlight set up correctly so you can see what you are aiming for is you best friend for doing this.
Remove the tie wrap someone put on there so you have more length.
Dennis
Old 03-08-2015, 07:45 PM
Thanks, Dennis.
Old 03-09-2015, 05:50 AM
TibetanT's Avatar
The CSV (cold start valve) plug is usually Blue from the factory, unless someone changed the end?
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 04-20-2015, 10:45 AM
