Spark Plug Hole Conditioning (Tool)
I'm relatively new to the forum. Great stuff and a great community.
I've read a number of threads here on spark plug removal with great interest. Last evening I removed mine from my 3.2 Carrera. A couple were a bit tough but by in large came out relatively easily using the factory tool.
I'm curious whether anyone has ever used a spark plug hole conditioning tool like the ones listed here: http://bgservice.com/docs/brochures/BG-Hole-Conditioning-Tool-20140122.pdf ? Specifically, is there any reason to use something like this?
Thanks,
Pat Arnold
Old 04-23-2015, 05:02 AM
I'll bet those plugs were in there for a long time. As long as you change them regularly, you should encounter no further issues, therefore negating the need for a plug hole conditioning tool.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 04-23-2015, 06:07 AM
5String
I've got a set of those things. The set was given to me. I've never had the need - or, indeed, the nerve - to use this tool. Seems like it would be awfully easy to screw up the threads. At least for me. A better solution, I would think, would be to use a little anti-seize compound on the sparkplug threads. Which is exactly what I do.
5String
Tell not a soul that you have seen me; breathe not a word of what I say....
The Northwest Files
Old 04-23-2015, 06:10 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Not to mention possible metal shavings in the engine ???
'85 Carrera Targa
PCA/POC
Old 04-23-2015, 06:14 AM
Those are useful if you've got a neglected motor that's had plugs in for a long time (resulting in carboned-up threads and lots of junk on the gasket seat). Be very careful if you use something like that on aluminum heads - one cross-threading incident and you need new threads...
Old 04-23-2015, 06:23 AM
Jose_JGC's Avatar
I see no need for that tool. For the past 24 years I have removed my 1970 911T's plugs about twice a year with no problem. I remove them with the engine cold, use the factory tool, tighten by hand on the tool as many turns as possible then tighten with the tool and lever.
Jose
1970 911T - Garage Queen
1982 Audi UR Coupe Quattro - G.Queen
2011 VW Touran - Daily Driver
Old 04-23-2015, 06:35 AM
Super wisdom from all. Thanks everyone!
Pat Arnold
Old 04-23-2015, 06:56 AM
wrxnofx's Avatar
I would guess the reason is for the post fallout of something like this:
broken spark plug Carrera 911 1987
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 04-23-2015, 07:07 AM
Under the radar
Trackrash's Avatar
Funny, it used to be that you were supposed to use anti-seize on plugs. And now Porsche says you aren't?
I still believe a small amount on new plugs is a good idea.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-23-2015, 07:18 AM
