wrxnofx's Avatar
Purchased New Handbrake Handle - Now What Glue to Use
I got a new handbrake handle for my '87. The original one had been cut off and an aftermarket leather sleeve was put on that includes the handle. As I'm returning to stock, I bought a new handle, and it needs to be glued onto the handbrake itself.
What kind of glue should I use? Will the black 3M weatherstripping glue work? Or do I use something beefier, like construction adhesive?
I'm gluing item #41 onto #8 in this image from PET:
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 04-25-2015, 09:49 AM
Member 911 Anonymous
DRACO A5OG's Avatar
So was #8 cut? Because normally you would use #40 to keep handle #41 in place.
'85 Carrera Targa
PCA/POC
Old 04-25-2015, 11:14 AM
wrxnofx's Avatar
Hi Jim. No, the button, #40, goes through the hole in #41. The handle remains stationary when you push the button, which compresses spring #37, which moves #14 and therefore #15, thereby letting the handle ratchet.
There is yellow glue residue all over the end of the brake from when the original handle was cut off.
Old 04-25-2015, 11:26 AM
wrxnofx's Avatar
Huh - no glue required. Plenty of resistance for a tight friction fit. It's always pleasantly surprising when a job becomes EASIER than what you anticipate.
Old 04-25-2015, 12:33 PM
DRACO A5OG's Avatar
Yeap, just like mine. I just screwed the button in and it stayed in place. No Glue Required
'85 Carrera Targa
PCA/POC
Old 04-25-2015, 01:35 PM
