Banned
Just a kiss?!?!
BTW - the KISS principle probably works OK with 911 a/c if you live in a not-very-hot climate or only desire a/c that will cool the cabin to the upper 70s, but if you want more from the system, then you need to do more than KISS it. Last edited by Ronnie's.930; 04-28-2015 at 05:16 PM.. |
Fleabit peanut monkey
Interested in what OP can pull of with the "kit" Also, don't let Ronnie get under your skin. He's a professional, you know. He was the key-note speaker at the recent Global Skunk-Butt Colloquium. Just saying.
1981 911SC Targa |
Banned
Waiting for your stink, chicken hed.
1981 911SC Targa |
1981 911SC Targa |
OK - I am going to chill to let Skip do his thing.
Very interested.
1981 911SC Targa |
Ticket to Seattle, you PU. |
Doubt he will have a come back.
1981 911SC Targa |
Banned
Banned
Banned
Banned
Bob, you are too funny.. lol Willard is Willard, what can we say............
He did make one good point in all the BS.. Have a 'professional' do the charge.. However, there are too many 'professionals' out there that don't have the right equipment to work on P-Cars.. It is well documented in other threads the equipment I use.. AND Charlie (Griff) states as much in his instructions.. If my car (black/black) needs the A/C turned off max in 90*+ here in SC than that's proof enough for me................
70 911T Sold 81 911SC Coupe84 Mustang Turbo GT 66 Galaxy 500 Ragtop (my Mother bought it new) 88 Thunderbird Turbo Coupe 69 Torino Cobra (R) Code |
1984 911 Targa - "Sabine"
Didn't have much time last night to work on the car, but wanted to feel like I achieved something none-the-less. I straightened out the new thermstatic tube and measured off the tygon tubing that I had purchased locally, leaving about the same amount of tubing exposed as was original with the white plastic sheathing, now way past its life's end. The tubing was the smallest I could get, and still has a very finite amount of space around the thermostatic tube based on its outer diameter (OD) and the tygon tubing's inner diameter (ID). With little to no difficulty, I was able to pass it all the way through, and am now ready to install it hopefully this evening as part of my evaporator work now due. Based on this ease, I wonder if this wouldn't be a much easier process than the original / OEM tubing - I know, that's sacrilegious, but then again, the AC system I'm installing isn't OEM either (it's BETTER!). Hope to get some pics online tonight if all goes well.
Skip 1984 (RoW) 911 3.2 Li Carrera - "Sabine" 2011 Cayenne S Last edited by Skip1; 04-29-2015 at 05:36 AM.. |
Well, tonight was a productive night, and I have a heck of a back ache to prove it, but all good. The evening started off with the removal of the evaporator box from the smuggler's box. Removal was fairly straight forward using Griff's instructions on angling the box towards the driver's side for ease of removal. Biggest challenge as highlighted was the drain tube protruding from the base, and the rusty hose clamps on the air outlet to the box. The fabric air tube was pretty well disintegrated / torn as well, but managed to remove that at the same time and cleaned off the hose clamps ready for reinstall. Once out, the amount of crap that I found at the bottom wasn't as bad as I was expecting - no dead mice.
![]() I vacuumed it all out, and wiped it down and started to work on the evaporator and motor replacement I had planned. Upon opening, it was no wonder the AC didn't ever work while I owned the car. ![]() Again, I cleaned off all the parts using light soapy water for the plastic parts so as not to ruin them, and then began work on replacing the motor. Wasn't difficult at all, and before I knew it, the motor & squirrel cage were balanced and reassembled with the new Kuehl Wirbelsturm. ![]() Then it was time to shift to the new evaporator and drilling of a new hole for the thermostatic tube, again, took my time and followed the instructions to the letter. Once the box was prepped, the base got reinstalled in the smuggler's box with insulating foam for the driver's side air intake followed by the insertion of the tin tube that accompanied the kit and then I pulled through the wiring for the fan from the new circuit control board in the passenger side footwell area (still haven't fed the thermostatic tube through, but that'll be next). ![]() Inserted the evaporator, and placed the cover on, reattaching the cover using the new self-tapping screws vice the clips, attached the new hose, and wired up the red/black (although it looked red/brown to me) wire from the control board to the new evaporator fan connector. Guess I just leave the old harness in place, as I'm not sure where that one goes. ![]() ![]() I then cleaned up the area cause tomorrow is supposed to be decent weather, and the car needs to move. ![]() As I said, the next step, tomorrow or Friday, will be to feed the thermostatic tube from the console to the evaporator and tidy up all the cables / wires, then it'll be onto the front condenser blower fan replacement I think, but will have to read the next pages of instructions again to make sure my order is right. That's it for tonight. Thanks for the supportive words.
Skip 1984 (RoW) 911 3.2 Li Carrera - "Sabine" 2011 Cayenne S |
Nice work
Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
I am following with interest, the A/C in my '88 is in need of an upgrade
thanks
1988 911 Carrera, M491 Cabriolet 2016 Cayenne |
Those refrigerant connections should be covered some how until you're ready to connect them up.
Expand on this, Skip. I see some corrosion but what did you see to think this was the cause of poor/no function?
1981 911SC Targa |
I know my 78 is different, but is the 84 model different from my '88?
I seem to remember the evaporator squirrel cage blower wheel in my '88 looking more complex than the one in these pictures. |
