Alignment gone bad
I replaced all the bushings, TB's, ball joints and shocks on the car over the last couple weekends. To wrap it up, I took the car over to the dealer for a 4-wheel alignment and they called today to apologize and told me they broke the car. I drove straight over and found this:
![]() According to the service rep, the car started rolling off the lift and the tech grabbed the window to stop it. They have taken responsibility to make it right but could not find a new frame in the system (NLA). I told them to check dcauto. We'll see how it goes. Sad day.
___________________________ Patrick 1987 Carrera Coupe (mostly done) 1974 BMW 2002 (new project) www.brokenboomerang.com |
Project Addicted
Damn, who doesn't place a chock on a lift with the car up there!? That doesn't bode well for the rest of the work.....
Jon 1966 912 1976 911 3.4 Backdate Project 1986 944 |
Sounds like it could have been a lot worse.
Find out what years that frame is on. Then look at the cars being parted out in the parts for sale forum.
1986 Bosch Icon Wipers coupe. |
workshop service
Patrick, this what i would do if it was my car.If the alignment was complete ok
pay the bill,-Now the accident,get in writing that the dealership will pay for any parts required to replace the Porsche back to the way it was originally.Tell the dealership you are sorry that this has happened ,and you you are going to replace the broken window area your self,or a friend that is an expert at repairing inside door repairs.there is a reason for this,your Porsche is better at home in your garage then in theres,and you will know if you do the job,which im not sure if you can, at least get some one that does know. example-- they could attempt to do the repair and break something else inside door glass as example --regards, Wayne. |
88 Carrera, Guards Red
compensation
Tell them that you are going to need a 2015 Carrera as a loaner. Or you will not be whole and will need advice of counsel.
i watched the guy the entire time with my 930.
i also do that when they put tires on. you never know where they will try to puta jack or lift on the under side of the car.
