Targa Top Pin Sheath Too Long
I'm rehabbing my new to me '78 SC targa top and noticed I do not have the plastic sheath's covering the two rear pins. I bought a couple from the local dealer but they look too long.
My grandfather would say it looks like a Norwegian bought a Swedish condom. I would never be that crass. Do I just push them on as far as they will go, or trim them so the tip of the pin sits inside the tip of the sheath? Here's a picture with the pin attached and the sheath taped next to it.
1978 911 SC Targa 2007 Boxster (sold) Last edited by KerryM; 05-01-2015 at 01:11 PM.. |
ROW '78 911 Targa
You need to remove the pin from the top to expose the full length of the pin.
Heat the new cover in boiled water to soften it up to help get it on. |
76 911S Targa
I used a Harbor Freight 1/4 inch deep socket and used that to hold the pin cover, then drove it on with a few taps from a hammer. Seems to work OK. No rattles like before. Never thought of doing what Timmy2 says. Sounds like a better solution.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
Fleabit peanut monkey
I would feel safer with the boiling water.
1981 911SC Targa |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Targa top pin.
All of the above posts are correct. Good luck, Gerry ![]()
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Thanks all for your quick responses.
Unfortunately I glued in the headliner last week so I don't have good access to remove the pin and do it correctly. I think I will cut off a bit of the base and then try the boil technique. I have a heat gun but I worry I will melt the sheath, so it will be plan B. If I cut off a bit of the base I will probably not be able to use the deep socket trick as there will be no lip for the socket to grab.
1978 911 SC Targa 2007 Boxster (sold) |
When it cool/tightens bet it will be secure.
1981 911SC Targa |
Softening the tips in boiling (or very hot) water is the ticket.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
