Question Hazard Warning Switch Q
My hazard warning light switch on the centre console does not light up at night with the other panel lights. But flashes red OK when the hazards are in use.
Q - should the switch be lit at night?
If so, any ideas on the source of the problem? How do I remove the switch to investigate?
Trivial problems, but it bugs me that the switch is dark at night.
Thanks.
"Racing is Life. Anything that happens before, or after, is just waiting"
1988 Carrera 3.2 Sport Coupe - my mistress
2012 BMW F11 touring - the dog bus!
2017 VW T6 Transporter - the holiday bus/workhorse
Old 11-14-2003, 12:17 PM
I have a euro '80 that works just like yours. The red hazard light only come on when they're flashing. I never thought about it until I saw a post here saying something about USA cars having the hazard light illuminated when the headlights are on. Perhaps it's a euro/USA thing? Does the hazard light switch illuminate when the headlights are on in a USA car?
-Rob
1980SC euro
Old 11-15-2003, 02:02 PM
Thanks for your post Rob. Perhaps there's no problem at all? Seems strange that it should not be illuminated - certainly looks strange at night.
Old 11-15-2003, 03:01 PM
Send a message via AIM to fintstone
US hazard buttons light when the headlight are on. Not full on, but sorta glowing. I suspect your's is the same. My '74 did not until I cleaned connections of a ground wire (brown) that went from the back of the switch to a terminal block under the dash near the ash tray. Several grounds were plugged in there..all correoded. From some of the dash and defroster panel lights.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 11-15-2003, 05:21 PM
Virginia Rocks!
VaSteve's Avatar
I'd have to say it's a bit weird to *have* it on. Since I'm a new owner, everytime I turn right, I see it out of the corner of my eye and think: what the hell is that!!
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 11-16-2003, 04:06 PM
