Franks89-911's Avatar
Securing a Size H6/Group 48 battery in a Size H8/Group 49 space...
Upon recommendations from others I went with a shorter H6/size 48 battery. Instead of the honkin big H8/group 49 size battery my 89 911 calls for.
But now its just laying there, unsecured. Any ideas on how to secure this battery so it won't go flying around up front?
Frank
1989 911 Carrera Targa 3.2L, all stock
78k miles (as of Dec 2023)
"The Machine"
Old 05-02-2015, 07:42 PM
My 84 has two holes for attaching the battery clamp. If your does not have two holes, maybe you can make a hold down clamp from a piece of aluminum or steel. Just a 2-3" bar with a hole in it should work.
Good luck,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 05-02-2015, 07:51 PM
My '80 also has two threaded holes for the clamp screw. I put in a shorter battery and used shorter hole - it was a bit tight (maybe because I put in an acid neutralizing pad under battery) - but it does fit.
Wayne
1980 911 SC
1960 MGA 1600
Old 05-03-2015, 04:14 AM
I have a group 48 in my '75 and there are two mounting holes in that tray as well. It fit/clamped in no problems.
Old 05-03-2015, 08:19 AM
