LinkBack | Thread Tools | Rate Thread |
Securing a Size H6/Group 48 battery in a Size H8/Group 49 space...
Upon recommendations from others I went with a shorter H6/size 48 battery. Instead of the honkin big H8/group 49 size battery my 89 911 calls for.
But now its just laying there, unsecured. Any ideas on how to secure this battery so it won't go flying around up front?
Frank 1989 911 Carrera Targa 3.2L, all stock 78k miles (as of Dec 2023) "The Machine" |
My 84 has two holes for attaching the battery clamp. If your does not have two holes, maybe you can make a hold down clamp from a piece of aluminum or steel. Just a 2-3" bar with a hole in it should work.
Good luck, Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
My '80 also has two threaded holes for the clamp screw. I put in a shorter battery and used shorter hole - it was a bit tight (maybe because I put in an acid neutralizing pad under battery) - but it does fit.
Wayne 1980 911 SC 1960 MGA 1600 |
I have a group 48 in my '75 and there are two mounting holes in that tray as well. It fit/clamped in no problems.
Thread Tools | |
Rate This Thread | |
