Wheel question on narrow body 911.
Been lurking on here for a bit and just purchased a 1976 911S with a 3.0 in it.
I have searched the forums and haven't reached a for sure conclusion on how wide of a rear wheel and can squeeze under the rear fenders.
I'm going to do the VTO performance wheels in 16" and have the several options in regards to offset and width.
Help!
Old 04-12-2012, 12:11 PM
privatepang's Avatar
Think 16x8" is the widest. I've heard ppl do 9's but have to severely cut / roll lips
1975 Aubergine 911S - Barney
"When that doesn't work, and it doesn't quite often, it's as though your face has been amputated." - Jeremy Clarkson
Old 04-12-2012, 12:29 PM
This is my '74 with Carrera Fuchs 6x16 front with 195/55/16, and 7x16 with 205/50/16 rear. I tried a 225/50/16 and it rubbed.
I've heard that 8x16, 951 Fuchs will fit in the rear due to a slightly different offset. On my car, I don't think anything wider would fit in the rear (i.e., 8" Carrera Fuchs) but some day, I hope to try an 8" 951 wheel.
porwolf's Avatar
Does this help?
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 04-12-2012, 12:32 PM
moneymanager's Avatar
You won't get a clear cut answer because there isn't one. 205/15's on 7's will almost always work; but didn't on my 74. Anything bigger than that may or may not work with your particular car and tire. You really can't be sure until you get them on and drive the car slowly and carefully around the block a few times, checking frequently for signs of rubbing.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 04-12-2012, 12:36 PM
912 Geek
T'ain't just the wheels, either. Among same-nominal-size tires, actual sizes differ between tire brands. Best way is to just try it (borrow or buy a used wheel and tire) and see. Bring spacers, too.
Frank
Old 04-12-2012, 12:54 PM
Amen. I carefully fitted tires and wheels on a previous car, then swapped tires. The new ones rubbed.
jhtaylor
santa barbara
Old 04-12-2012, 12:56 PM
It's currently set up with 225/50/15 rears on 7" BBS's and 205/50/15's on 7" BBS fronts, car is very, set up for autocross, no rub on this set up.
Old 04-12-2012, 01:30 PM
cmpski's Avatar
These might help. Sometimes it helps when you can "see" the different offsets or know exact measurements of one tire size to another. I understand not all tires of the same advertized size are the same and what works for one car might not work for another. They helped me.
http://www.sjdsm.com/tech/tire_size.htm
I have often wondered if we are putting too wide of a tire and too sticky of a tire on these old cars. They were pertty loose and unstressed back in the day with bias ply and early skinny radials tires. Are we quickening their usefull service life to a point that we will be offering the next generation, cars that are all used up. I hope not. I'm glad the orginal owners passed on a car with lots of life left.
Old 04-12-2012, 01:32 PM
sure but remember 225 is still a pretty narrow tier. Just as a data point (i know its not the same) on my SC Race car, I can run a 17" 275/45 on the rear with just a little rolling of the fender lip. But i am also running CCW wheels which are a custom offset (I can't remember, what it is, my old mechanic had CCW make them in that offset). I have put 9" fuch's on the rear in 16 previously and had no issues running 275.s Fronts, I can squeeze a 235 in, but at full suspension compression, there is a bit of rub, even with the fenders rolled
Old 04-12-2012, 01:34 PM
On my 1973.5 911T I run 225/50/15 rear and 205/55/15 front on 15x7 Cookie cutters. No issues and no fender rolling was required. Tires are Falken ZiEX-912. If I lowered the car a bit more and/or went to 16in wheels I may have to roll the back fenders.
- 2014 Porsche Cayman - Guards Red/Black
- 1986 Porsche 911 Carrera 3.2 - Silver/Burgundy
- 1973 Porsche 911 2.7S - Aubergine/Black - 2200 lbs !
- 1980 Porsche 931 - Malaga Red/Black (sold)
- 2015 VW Golf 1.8 TSI
Old 04-12-2012, 01:56 PM
1974 911 w/ 83 SC engine
I have a '74 with 205's up front and 225/45's in the back, 16" Fuchs. Rear fenders are rolled. Falken 452 tires. All that being said, I can't imagine fitting a bigger tire back there, period. I could maybe squeeze a 225 up front on a 7" wheel if I rolled the front fenders, but 225's on the back is pretty much as big as i have ever seen on a narrow body.
Old 04-12-2012, 02:18 PM
faverymi's Avatar
Interestingly....
Throw suspension setup into the equation..... and guess . Start over.
I'm dealing with the same issue in a narrow body. I just like euro height. I'm trying to get the lowest setup with the widest tire on a 16-7 fuchs. The silver car on the top pic looks perfect!!!. What brand of tires did you install?
Probably going with 205-50-16 in the back. with 16- 7" fuchs. I don't have 15 fuchs so I'm not even going to think about 15-7 or 15-8 fuchs on the rear.
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 04-24-2012, 03:16 PM
Got my wheels! 205/45/16 and 225/45/16 tires on 7" wheels, handles like a dream!
Old 04-29-2012, 01:38 PM
Living the Good Life
Phares's Avatar
What brand tires did you end up going with? I'm the market so gathering intel.
Chris
1974 911
Old 04-29-2012, 06:37 PM
Didn't have much in the way of options, ended up with BF Goodrich, not in love with the tread pattern but the performance is good so far. If I had it to do again I would have done the 50 series front, would have fit and looked a bit more era appropriate.
Old 04-30-2012, 04:48 PM
Phares's Avatar
Thanks! I have 6&7x16s and I think Goodyear GTs are the only matching pair I can find to fit. 195/55/r16 and 205/50/r16 is a hard combination to find.
Chris
1974 911
Old 05-01-2012, 07:49 AM
Send a message via Yahoo to Lukesportsman
Looks great! Rims set off the Al window trim quite nicely against body color for a very nice balance.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 05-01-2012, 09:24 AM
Took a nice drive Sunday evening and shot this one, can't wait to get on with the rest of the mods!
Old 05-01-2012, 10:06 AM
'74 911 Targra
Very nice look! Did you decamber front or rear? Is you car too low for average driving? Spoiler looks close to the road. I have installed a test fit of 7x16 with 225/45/16s for the rear. Seems to fit, but car needs to be lowered to look correct.
Have not chosen front tires until I dial in the back. Your 50 suggestion is probably right for the front.
Thanks!
1974 911 Targa
Old 06-21-2012, 11:27 PM
