I am planning to rebuild the brake calipers on my 1980 SC using your caliper rebuild guide. However, the Pelican parts package that the tech article on your site takes me to, refers to piston seal and dust boots for 911 vehicles only up to 1974. Are these same parts suitable for a 1980 SC?
This post was auto-generated based upon a question asked on our tech article page here:
Old 05-08-2015, 10:07 AM
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2014.cgi?command=see_more&please_wait=N&db_record_number=41904&PART_SEARCH=Y&SUPERCAT_FLAG=Y&make=POR&description=91135194600%20
That should be the front...
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2014.cgi?command=see_more&please_wait=N&db_record_number=41905&PART_SEARCH=Y&SUPERCAT_FLAG=Y&make=POR&description=91135299800%20
That should be the rear... One hint I have from experience, the brakes will feel unusually spongy after rebuilding the calipers. Just make sure you have all the air out of the system and then brake with confidence.
- Casey
Member 911 Anonymous
DRACO A5OG's Avatar
Make sure you use Syl-glide lube for the assembly. Use brake fluid to insert the inner seal then lube to coat the inner part of the caliper where pistons ride and a lite coat of lube on the piston. Insure piston is not pitted, if so, you need to replace as a pair of four or this task is a complete waste of time.
Put a generous layer of lube on the under side of the dust cover and around the piston, this will keep further corrosion and insure an air tight seal.
When putting the pads back in, do not push the pistons all the way in, make sure you push in just enough to slide the pads in with little to no effort.
Just did mine and had to replace some pitted pistons
'85 Carrera Targa
PCA/POC
Old 05-08-2015, 11:42 AM
How did you squeeze the rear caliper's dust covers into place?
Old 05-08-2015, 12:01 PM
DRACO A5OG's Avatar
The trick is:
Remove the retaining barbed ring carefully.
Take a flat faced plyer, I used my large needle nose plyer and squash down every other barb. Re-insert the ring making sure it is in it's proper place by comparing to the un-molested one. Repeat.
This allows just enough tension to catch the piston lip and stay in place. As you never push the pistons out all the way by accident or intentionally it will stay.
Centric also make a seal kit with the proper dust boot with retaining ring on the outside per PAG OEM design. But their inner seal is not proper. I am planning on replacing the boot with Centric because I have OCD.
'85 Carrera Targa
PCA/POC
Old 05-08-2015, 12:07 PM
Thanks, and clever idea on the barb squashing!
Old 05-08-2015, 02:08 PM
DRACO A5OG's Avatar
Can't take credit a fellow pelican posted it and I'm just sharing it
'85 Carrera Targa
PCA/POC
Old 05-08-2015, 03:27 PM
Oh Haha's Avatar
I didn't realise you could put that many words into the title of a thread!!!!!
Pacific Blue
Wayne
Old 05-08-2015, 04:29 PM
DRACO A5OG's Avatar
LOL, actually he ran out of space
'85 Carrera Targa
PCA/POC
Old 05-08-2015, 04:33 PM
Longest title ever .........
That's the longest title I've seen in my entire life. And nothing after the title. You learn new things everyday.
Tony
Old 05-08-2015, 04:44 PM
DRACO A5OG's Avatar
Come on Fellas, play nice
'85 Carrera Targa
PCA/POC
Old 05-08-2015, 04:47 PM
Brew Master
cabmandone's Avatar
Alright, now ya got me nervous. I installed Centric seals in my calipers a few months ago. I'm curious why the inner seals aren't proper?
Old 05-09-2015, 04:08 AM
Subscribed.
Wayne
1980 911 SC
1960 MGA 1600
Old 05-09-2015, 05:57 AM
Yeah, and what's a "pair of four"?
Old 05-09-2015, 10:54 AM
DRACO A5OG's Avatar
LOL, you are correct, I meant "Pair" of calipers so doing two calipers at the same time requires 4 pistons. Good Catch
A trusted Pelican advised against it, apparently he tried them and he suggests the retraction action of Centric inner seal is not at the same rate as the FTE product. Maybe he got a bad batch? Don't sweat it, if it works then it works.
Let me find his post and link it: 3.2 Rear Brake Caliper PISTONS, Source? Post #5
'85 Carrera Targa
PCA/POC
Old 05-09-2015, 11:12 AM
