Help identifying a serial number
Hello
I've just found a 1971 911E that supposedly has a non original engine. The engine serial number is 902XXX. I can't find any information on six cylinder engines with a 902 nomenclature, does anyone know what engine is this? Thanks Mauricio
"With an stock-original car, you serve the car. With a hot-rodded car, the car serves you." Last edited by enzoducoing; 05-09-2015 at 05:52 PM.. Reason: . |
Fleabit peanut monkey
Was the number in this location? Just to the right of the fan when looking into the engine compartment?
Should be seven digits
1981 911SC Targa |
Serial numbers 900001-903550 is from a 1965 coupe engine number 901/01 gearbox 901/0 mated to chassis
numbers 300001-303390 some one might be looking for that engine. What carbs does it have? Should be Solexs. Last edited by durangoflat6; 05-09-2015 at 01:42 PM.. Reason: Read the wrong line |
1981 911SC Targa |
Engine 902186 is a 1965 built around april- may 1965 had solext carb 130hp alu case and serial number should face you instead on side.
Thank you
Thank you all and specially pors1968 for the detailed information, I guess is a keeper then. Mauricio
"With an stock-original car, you serve the car. With a hot-rodded car, the car serves you." |
I should add $$$$$ engine.
gearhead
I wouldn't call it a keeper. It has zero value to your car. Has a tin if value to a '65 owner. Sell that engine and build yourself a totally badass ST spec mfi engine for your E with the proceeds. Seriously.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 Last edited by Matt Monson; 05-09-2015 at 07:30 PM.. Reason: typo |
value
Does anyone know what would the value of such engine be in correct restored condition?
Thanks Mauricio
Do you have the solex carb set up .
Solex
You are in business restored 28-35k probably more if you find car it belong.Exaust valve cover should be 6 bolts.
If you have engine # 902098...I'd be your huckleberry...;-)
Nice work, pors1968.
1981 911SC Targa |
