Driver power window dont work
Ok go out to my car yesterday the window will not go down. The passenger side works from the driver side and passenger side.
test light getting power to the red wires. I take the switch out of my other car still nothing. I disconnect the blue/black wire window goes down. I plug that wire in and disconnect the blue wire window goes up.. ![]() ![]() ![]()
I'm not tracking the entire troubleshooting flow.. but it sounds like a a bad switch. Take a switch from the passenger side and see if that works / fixes the problem.
Also can check for connectors slightly touching on the back of the switch. My car the previous owner looked like he had put larger connectors on, and I had to isolate them even more by wrapping the connector ends with some electrical tape. Pretty sure the sunroof, and both windows are all on the same fuse. So if the passenger side works, the fuse shouldn't be the issue. Good luck
-Derek '84 911 coupe Last edited by fitchesbass; 05-10-2015 at 07:08 AM.. |
Rick 88 Cab |
what car is this?
where did the blue wire come from?
Rick 88 Cab |
That's right. I looked at the wrong page in the Bentley.
Rick 88 Cab |
Since those two wires go to the motor that makes no sense unless there is a connection to ground inside the motor or wiring to the motor. I think there is a thermal protector in the motor so you could let it cool off, disconnect it and check for a path to ground through the blue wires.
Rick 88 Cab |
Just out of curiosity does anyone know off hand what type of motor a power window has? Is it a permanent magnet or does it have a wound field (series/shunt)?
Rick 88 Cab |
Member 911 Anonymous
Switch the Switches around to confirm it is not a bad switch or take an ohm reader to it.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
He already did that which is why I'd be leaning towards the motor. That is the magic one that works with only one wire connected.
Rick 88 Cab |
Oops my bad.
Time for a door panel removal, oh the joy
the passenger side works fine with both switches i flip flopped several switches already. If it were a ground would both switches still work the passenger side.
The blue and the blue/black wires should be the only electrical connection to the motor. If you disconnect one there is no path for current to flow, hence the mystery. If you knew what type of DC motor it was it would be easier to speculate on the failure mode. Measuring the resistance from the blue wires to chassis should be telling.
Rick 88 Cab |
