Red face No compression cylinders 2&5 p911 1977
All cylinders except 2&5 showing 110 psi, that's a cold engine 13c air temp. Cylinders 2&5 0psi. Engine has new rings etc. Could the guy I got to do the cam chain timing, have got it this wrong.
Please help.
Old 05-14-2015, 02:40 AM
pors1968's Avatar
No i would bet on guy who did valve ajustement.
Old 05-14-2015, 02:51 AM
Agree, valve adjustment too tight
Bruce
Old 05-14-2015, 03:53 AM
Valve adjusting method......
Please help.
Vanillamitch,
We're you using the backside method for valve adjustment? Or the conventional way. Just curious.
Tony
Old 05-14-2015, 05:59 AM
Straight shooter
Lapkritis's Avatar
Having gone too tight on a valve adjustment myself, they sure do run nice and quiet but way down on power. You would notice right away... I made it about a mile before turning around to do the job over.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 05-14-2015, 06:43 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1, have valves re-adjusted or DIY and send him the bill.
'85 Carrera Targa
PCA/POC
Old 05-14-2015, 10:26 AM
