washed engine and now..
No spark. I removed the cap & rotor and hit it with the air hose and dried it all. My wires all had a very good seal to the cap and the plugs. I had a MSD coil on the bench so I put it on, still no start. 12 volts at the + side of the coil. The intake tract is dry. Is there something else that gets wet and causes this? I was pretty through with the cleaning.
![]() For now I have it on the charger and the cap and rotor off, airing out in the nice ocean breeze. I'll get at it again in the morning. I also removed the fan assembly and painted the fan. After it would not start I pulled it all out again and checked the wiring, all ok. The alternator was in the garage while I washed the motor so it did not get wet. Thank you, Mike |
I would spray wd40 in the cap, it dissipates water.
Tom Feeney 1970 911 T 1973 911 T Looking for engine 6103643 |
Fleabit peanut monkey
Blow out the 14 pin connector on the driver's side rear. It's a biggie. 12 pin connector just to the right of the drivers side shock also.
1981 911SC Targa |
Nothing good ever comes from washing your engine....
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
What year is your car?
wet engine
It will start, put the original coil back on,.using air is not a good idea, it forces water
down into cracks and crevices down inside the distributor . This may sound strange but its true,you use a damp cloth to remove water, then finish with a dry cloth.Also take extra look into the coil connection at top ,pull the connection and dry there. same with top of dis cap , or clean with fine wet dry paper on the end of builders punch inside, .It can turn the copper connection inside coil - green- with corrosion over night.-----Ask me how i know this. |
Thanks for the replies. The car is a 1984.
Banned but not out, yet..
Change user name to Not So Fast Mike? At least until solved.
An air cooled refrigerator. ‘Mein Teil’ |
How old are your plug wires ?
I bet it starts right up today.
1986 Bosch Icon Wipers coupe. |
Use the air compressor to blow dry:
14 pin connector at the front of engine, next to left side shock tower. Disconnect clean and reconnect idle valve three connectors to the left of the intake manifold where the head temp sensor goes MAF sensor connector Disconnect each plug wire, inspect for water pooling, dry them and put them back Now, see if it starts.
i was my engine all the time.
if wiring is good there are no issues. better to find out at home. check the connectors for the CPS and I think you have a speed sensor or something like that. not much to prevent spark.
Mine is an SC. There is a 12 pin (maybe 14) to the right of the shock tower on the frame/beam of the engine "hole". Hole means what you see if the engine is out.
14 pin connector is way in the drivers rear of the engine compartment. Rear meaning bumper. You have a couple of connectors for sure, just not sure where on the 3.2.
1981 911SC Targa Last edited by Bob Kontak; 04-12-2017 at 10:51 AM.. |
Except a cleaner engine.......
I have washed mine many times. No issues.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Well after drying overnight and drying out all the connectors it fired right up. I there a gasket or something to water proof the distributor? Seems rain water just pours in right on to the distributor.
Mmmmmm, nice and clean too.
'71 914-6 #0372 '17 Macan GTS |
Just like a 65 Bug! I remember seeing bugs driving around town in rainy weather with clear plastic wrap over the lid slots! In the old days.
I live on the beachfront so I wash the SC engine down about once a month. And probably once every year or two I spray it with degreaser and hose it down. I've never had a problem, not even a missfire. Something's not right.
Why not just use some clean rags and some light spray cleaner and some armor all for the rubber parts? And then some metal cleaner for the fan while you are there. Takes me about 30 minutes and have coffee or beer while I clean. Why spray water if you don't have too? Why would you spray water on electronic parts when you don't have too?
