K&N Air Filters--Any Cons?
Are there any reasons not to install a cone style K&N air filter on a 3.2 engine? I would expect some increase in induction noise, and that is OK. Since the Motronic uses an O2 sensor, I assume it will compensate for the reduced restriction to the air supply and with the closed loop operation there will be no problems with excessive lean-ness of the fuel air mixture. If I am wrong, please point out where and why. Thanks.
K&n great filters
Dirt in your engine a concern?????
I've driven alot of crap to get here man! |
Banned
Agreed - I've used them for over 20 years, on everything from racebikes to a 7.3L diesel (and Porsches, too), and never had a problem of any kind. Some people report an increase in dirt, and/or the oil used on them getting spread around in the intake, but I haven't experienced that . . .
Hold one up to a light and observe all the holes where fine dirt gets through. Paper for my engines.
+1 for the stock filter.
George M '89 Carrera 3.2 '91 928GT '76 914 '18 Macan GTS |
Checked out
That's a pretty simple task for even a mediocre engineer, and at Porsche I think they were above average. |
Checked out
In other words, their are a lot of restrictions to the intake air supply. The throttle body, runners, heads, intake valves, etc.
What makes you believe that the stock air filter is the bottleneck? |
Dirt in your engine, no HP gain
Dirt.
plus if you clean and over-oil it (almost always happens) you get oil mist screwing up the downstream sensors. |
Reiver
Went back to a paper element and no dirt whatsoever in the carbs. Ok for a racetrack, not good for the street.
De Oppresso Liber Strength and Honor 5th Legion |
Racing engines are OK with K&N, BMC, and any matter of oiled foam air cleaners since these are rebuilt on a regular basis. Street engines, OTOH, are expected to last 100K to 200K miles and using anything but a factory paper air cleaner element is totally counterproductive toward that objective.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
I went back to paper filters after seeing how much dirt passed through the K&N and settled in the airbox and beyond.
Hugo
Present: 1984 928S/Indischrot, 1994 968/Polar Silver Past: 1979 911SC Targa/Petrol Blue |
I bought my K&N filter because I have run them on my good weather cars for many years. It was one of the first things I bought for it.
The guys here posting that they use paper are some of the most respected names(to me anyway) and have more experience than I. However, I have not found dirt in my airbox as others have. I do not drive on dirt roads and MI is not exactly known as a dusty state. My car has close to 200,000 miles and is still going strong.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
I've been pretty happy with K&N's over the last 4 decades. I don't fit them for HP.
The two most common mistakes seem to be over oiling and cleaning too often. There's a specific amount of oil you're supposed to use, based on filter area. The recharger kits contain lots of oil. You're not supposed to use it all.... The service interval is 50,000 miles for most people: Quote:
Both quotes from K&N Air Filter Facts You Should Know
'77 S with '78 930 power and a few other things. |
Except at WOT and "full throat" the throttle plate is THE major airflow restriction.
If you're a participant in the 24 hours of Daytona, fine, otherwise.... Last edited by wwest; 05-16-2015 at 07:58 AM.. |
Downsides...
1. Cost 2. Fitment (many gte their mesh damaged by the plenum mounting node for the original air box 3. Weight. Weigh more than the OEM intake. 4. Maintenance (more of it) 5. Finickey (see above. Over oiling) 6. Dirt (trust me, not worth the small gain it might give in power, when you consider engine life and costs) 7. Lack of power gains over a open or drilled airbox with a clean filter (Steve Wong told me he runs a open airbox with paper filter and it is about as good for flow as a K+N cone filter, but lighter)
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS |
Here is my completely open, honest answer: the K&N can be great - and I've run them. But, I know me. I'm FAR more likely to simply click and order a new filter from PP and install it, than getting around to the mess and bother of cleaning the K&Ns and then oiling them. Nothing against the K&N. Just my SOP.
I use a BMC conical filter. It does not provide some of the disadvantage listed by gliding_serpent:
- fits without any issues - is lighter than the stock airbox - provides a noticeable power difference to the drilled stock airbox it replaced It needs a properly designed adapter to create a smooth airflow from the round filter to the rectangular AFM intake. A simple adapter does kill all the gains. At certain throttle settings it produces quite noticeable noise, but my car is gutted of all interior sound deadening, so it might be worse compared to others ![]() The gentleman who designed the adapter actually suggests turning the AFM 180° to achieve the same set-up as on a 964 engine. I have no tried that yet. |
and this is how a properly designed adapter could look like:
