Kartoffelkopf
Spenny_b's Avatar
Re-plating an item with a rubber insert?
Hi guys,
I need to get the gearbox stabiliser bar on my 964 Turbo replated.....
However, the rubber insert is fixed in place; looks to be a case of bending over some tabs - even if I machine these out, my guess is that it'll be stuck fast after 20yrs of weather.
I just spoke to my plating shop to see if the chemicals they use would affect the rubber. In short he simply didn't know, he's happy to try but at my risk.
I know nyloc nuts are fine being plated, e.g. putting a gold passivate finish on BZP nuts....but does that logic hold true for rubber as well? Anyone been down this route?
(my Plan B is to make a whole new unit using a rose joint instead of this cylindrical damper, but retaining the 2x donuts that fix into the gearbox>chassis crossmember. I'm using a TurboKraft tail mount that's approx equal to 964RS stiffness, plus a Goldenrod shift linkage, plus 964RS engine mounts) --->
Thanks in advance
Spencer.
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 05-18-2015, 02:12 AM
When having stuff plated in the past I used the plater's advice to use paint as a mask for those areas I didn't want plated, such as in my case the mating surfaces and cilynders on a set of brake calipers. It worked very well, so I would imagine that if the acids they used couldn't damage oil-based paint then your rubber parts should be OK? Maybe get an old bushing from a local breakers yard and have your plater see if that gets affected in any way?
'70 911T (AKA Bottomless Pit) - Undergoing restoration
'13 Audi A4 1.8T - Surprisingly fun means of getting to work
Old 05-18-2015, 03:14 AM
Kartoffelkopf
Spenny_b's Avatar
Yup, good point with respect to finding another sacrificial item to experiment with - I'm bound to have *something* kicking around the spare parts bin.
Cheers
Spencer
Old 05-18-2015, 05:36 AM
Good question, I'm having the same dilemma.
Could masking with liquid electrical tape work?
Mauricio
"With an stock-original car, you serve the car. With a hot-rodded car, the car serves you."
Old 05-18-2015, 06:54 AM
Send a message via Skype™ to Porboynz
I think it will be just fine, my engine and gearbox mounts came out fine and so did the door latches. 3 years on they are still OK
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 05-19-2015, 09:39 PM
SoyRacer's Avatar
No worries regarding the rubber. I've had fuel lines with rubber lines still crimped on re-plated and no issues whatsoever. Just make sure they don't dip it too long in the cleaning acid and it'll be fine.
See my Instagram page and you'll see what I mean.
1973 Porsche 911 RS
1981 Porsche 931 Euro-Intercooled-GT
1984 Porsche 911 Euro Carrera widebody
1987 Porsche 924s Rallye Spec
Instagram: @soyracer
Old 05-19-2015, 09:52 PM
Kartoffelkopf
Spenny_b's Avatar
Thanks fellas, v useful feedback.
I dropped the items over to the plating shop yesterday with a spare exhaust mounting bobbin, with instructions to try that first, if successful then go ahead and plate the stabiliser. They're anticipating it being done tomorrow before our public holiday weekend....we'll see if it lived. Or not.
Ta
S
Old 05-21-2015, 11:27 AM
douglas bray's Avatar
My go to guy for plating is Einmalig. Motor mounts, drop links, spring plates, and the like are all plated with rubber in place. Does not effect the rubber at all.
Old 05-21-2015, 01:46 PM
