Perpetual Reassembler
2jmotorsports's Avatar
Belly Pan Dent
Is the belly pan covering the fuel pump supposed to have this huge dent in the top right corner? I did not see any parts under the car that looked like they require that feature for clearance. 83 SC.
Time to get a big hammer?
Old 05-29-2015, 01:59 PM
Eva
911SauCy's Avatar
BFH (Rubber if you dont want to repaint)
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 05-29-2015, 02:02 PM
Perfect. Thank you.
Old 05-29-2015, 02:04 PM
Was that actually installed in that condition? It looks like the bending in the upper right is sufficient to actually move the right front bolt hole, and it should not fit. If it WAS installed in that condition, it suggests that the RF's matching bolt has been moved aft from its original condition. And that might be a serious problem.
Old 05-29-2015, 03:50 PM
Fleabit peanut monkey
Bob Kontak's Avatar
+1
Beat it flat as a tortilla. Tweak it here and there to make the bolt hole align. Spray with Rustoleum "professional" paint.
1981 911SC Targa
Old 05-29-2015, 08:36 PM
Lost in the 1660s
drmac's Avatar
This response gives me hope.
1978 911 SC Targa
Old 05-30-2015, 07:07 AM
bavaria911's Avatar
Here is mine sand blasted with fresh Rustoleum black paint.
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 05-30-2015, 08:37 AM
Sexy. I beat mine flat but haven't painted yet. Still chasing fuel pump issues.
Old 05-31-2015, 09:42 PM
TheSt|G's Avatar
Mine had some big dings in it, but nothing that interfered with its function. Just sand blasted and powdercoated it for another 30 years of use. It gets hit by rocks and junk all day, so I don't really care if it looks factory fresh.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 06-01-2015, 06:20 AM
To conclude the thread, I did have some bolt hole spacing issues after pounding out the dent. However a few taps with a ballpeen hammer and measuring the hole spacing with a tape measure did the trick.
Also for future reference the driver side sway bar bracket (which is also held down by one of the pan hex bolts) was difficult to line up by hand due to the tension of the swaybar (?). I very lightly compressed the swaybar just outside the left edge of the pan with a bottle jack and was able to get that bolt on. The rest bolted up with no issue.
Thanks again for the help!
Old 06-03-2015, 09:42 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Good job using the jack to counteract the sway bar's ability to create misalignment. I've seen a lot of people try to use the bolt to align things and 9 times out of 10 it ends up messing up the threaded bung in the chassis.
Kevin L
'86 Carrera "Larry"
Old 06-04-2015, 08:24 AM
