Speedo and Odometer both stop working
I went to go for a drive the other day in my 84 Carrera and the Speedo cluster was not working at all.
I have read all about the gears wearing out but that is always just for the odometer, I bought the car a year ago and the pervious owner had replaced the gear in the cluster, so I am not sure where to go next.
Any ideas?
Old 05-28-2015, 01:28 PM
ROW '78 911 Targa
timmy2's Avatar
Check the connectors in the shift coupler area in the tunnel between the rear seat floor under the cover. One may have come loose.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-28-2015, 04:33 PM
petercory
More than likely a capacitor and/or diode has died. The capacitors should have been replaced along with the odometer gear(s).
Old 05-28-2015, 04:48 PM
RETIRED
Joe Bob's Avatar
Put it in another 911. See if it works. If not it's the gauge. Needs an overhaul. If it DOES work it's your wiring.
2012 ML350 3.0 Turbo Diesel
Old 05-28-2015, 05:03 PM
speed transmitter went out and after that the speedo did not work, so I sent it to NH Speedo.
Old 06-19-2015, 06:14 AM
speedo came back and everything is back to working.
Old 07-08-2015, 07:35 AM
