-   -   Battery drain - fog lights to blame? (http://forums.pelicanparts.com/porsche-911-technical-forum/867800-battery-drain-fog-lights-blame.html)
darrin 06-03-2015 02:57 PM
thanks -- I'll be sure to limit my advice on this issue to '84 and newer 911s going forward :)
ganun 06-03-2015 06:39 PM
Sorry for the dead end, didn't realize the year
Bob Kontak 06-04-2015 08:25 AM
I knew it was too good to be true.
Does the relay drop the window a bit and then lift it back up to seal it up tight in the door after it shuts? I don't remember seeing that on cars until the 1990's.
darrin 06-04-2015 08:59 AM
No, it simply leaves the window circuit active so you can roll up the windows after turning off the ignition, but before opening the door.
Smoove1010 06-04-2015 09:23 AM
I just went through this earlier in the year (http://forums.pelicanparts.com/porsche-911-technical-forum/848015-battery-drain-87-cabriolet-not.html) and the problem was indeed the power window relay being energized all the time, though not for the typical reason. In the process of fixing this issue I resolved a fuel-pump-always-runs issue as well. Lucky for me I like solving puzzles and got some excellent support from knowledgeable Pelicans. Like everything else I've done to the car, going through the process was a great learning experience.
Since then I've gone weeks without starting or charging the car with barely detectable drain on the battery.
Good luck!
GK
Bob Kontak 06-04-2015 09:27 AM
Not a dead end. Just another learning opportunity.
Now there are a handful of folks that have this new knowledge.
