Battery drain - fog lights to blame?
Im trying to track down a drain on my battery that leaves me with a dead battery if the car sits for a couple days. I just replaced the bulbs for the fog lights on my 83 SC a couple days before this started happening, and that is the only thing I can think of that might be a source of the problem. Anyone know of any issues associated with fog lights on an SC that are known to cause any similar issues?
Take off the fuse but i dont think that your problem.Check your battery.
Right - get the battery load tested first. If that's not it, then:
Make sure your interior light is not on - a three-way rocker switch with off/on/on-when-door-is-open. It's easy to knock the switch into always-on, and it's easy to not notice. if it's not that, disconnect the battery ground cable and connect an ammeter, then pull fuses one by one until you see the drain go away. The other common culprit is a malfunctioning aftermarket alarm or stereo.
John 1972 911T 3.0L Coupe 1986 Carrera Targa 1989 BMW M3 2007 328iT |
RETIRED
Light under the dash was the culprit once for me....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
trunk light switch sometimes does not go off
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Thanks. I'll take a look at each of these. It just seemed too coincidental that I never had any electrical issues until 2 days after replacing the fog light bulbs.
Fleabit peanut monkey
Those probably pull between 0.5 and 1 amp.
If you don't have a MM, you can cheat by pulling off the negative battery cable. When you touch it back onto the terminal you will hear a micro sizzle as the two try to weld themselves together. Pull the fuses one by one and wait for the noise to stop. This assumes that the battery is fine and gasoline is not pooled up in the battery tray.
1981 911SC Targa Last edited by Bob Kontak; 06-02-2015 at 07:01 AM.. |
on mine it was the FENSTERHABER relay sticking, I foung the issue using the same Bob K trick,m but I actually heard the faint relay click.
87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T |
the Fensterhaber/window relay can remain activated/armed (and draining current) if the door switches that trigger the interior light fail -- does the OP's interior light come on when either/both doors are opened?
Darrin, So if the jamb switch does not turn on the lights, then the FH relay stays activated , draining juice, waiting for the light to turn on signifying the door has opened and cutting power to the windows ....right?
That system is so sketchy, its failure mode is almost invisible to the operator....then you drain the battery.
Expand on this a bit, please.
1981 911SC Targa |
I believe the relay is triggered by either door opening. So, if the passenger door jamb switch still works, opening the passenger door should trigger the relay and cut power to the windows/eliminate the parasitic drain |
This thread was timely for me - I *thought* I had identified the battery drain issue in my just-acquired '72 just a few days ago - the aftermarket stereo is not wired to a switched circuit, it's always hot. And, every time the battery is disconnected, it turns on when power is restored. So - I had assumed that I was just leaving the thing on by accident, and made it a point to verify it was off when I shut the car off. I should just take it out - the M&K is so loud, it seems silly to even have a radio in the car. But - this very morning - I go out to start the car and the battery is drawn down again, and I look and the stereo is definitely off.
Tonight I started over - I tried the ammeter as I thought I so cleverly suggested above, but found out that my digital multimeter is broken as an ammeter (it is 20 years old and kind of flaky - makes me wish I had kept my old analog meter) . Anyway, that didn't work, and the individual fuses didn't seem to spark as I pulled them. So I checked my frunk and interior lights which seemed to be operating correctly. On a whim, I shut off the lights in the garage to make it completely dark - and voila - there it was - the engine compartment light was glowing through the grille. The cover was rotated mostly shut, but not quite, so it has been on constantly. Doh!
Onward, to more likely culprits... JR |
jdbunda, your engine compartment light should be connected to the sidelight circuit so it can only come on with the sidelights/headlights and not have a continuously live 12v supply.
Cheers, Neil |
OP's car is an 83. The fenster-miester relay started in 1984.
1981 911SC Targa |
Not sure what a Fensterhaber is but most cars have a Fensterheber.
The juice draw makes perfect sense. Relay is energized just waiting for you to close the window but it does not know you opened the door. I found ganun's thread on his relay and loaded the 944 prefix number into PP's search engine. That relay is for 84 an onward.
1981 911SC Targa |
