Burnin' Rubber
Front Shock Tower Mount Rupture Help
After a very mildly spirited drive, the front passenger strut started squeaking. So I pull back the carpet to find this:
![]() The squeaks are much much worse after a few miles heading back home. Incessant, constant, loud squeaking ![]() What is the best way to repair this? Are there reinforcement plates that can be bolted or welded in? It's hard for me to tell because of the black goop but is this a very serious rupture? |
rupture? are you talking about the crack in the black goo?
looks normal from here. for the squeak, might be the torsion bar rubbing the inside of the control arm- also check the sway bar bushings
Jason 81 SC 97 328is 87 Jeep Comanche (RIP) |
^^^ That shock tower looks normal.
You have some worn bushings somewhere else in the suspension..probably the anti-sway bar as jason suggest.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current) 1989 911 Targa (sold) 1996 993 Cab. (sold) 1999 x2 Boxster (sold) 2006 Cayman S (my daily) |
RETIRED
Could be bushings as mentioned or a failed strut. Take it to an alignment/suspension shop for a diagnosis.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Going to suggest that that car has probably never had an alignment and by now, your rubber bushings are probably shot. The important ones are the control arm bushings and the spring plate bushings.
I'd suggest taking it to a 911-knowledgeable shop and having all that stuff refreshed. Maybe new shocks/strut inserts, too. JR |
Reiver
To satisfy your curiosity peel back the goo a bit so you can see the solid underbody....
Remove the tire and jack it up...support it properly and move things around a bit to find you squeak....if it is that prevalent shouldn't take much.
De Oppresso Liber Strength and Honor 5th Legion |
Member 911 Anonymous
Koizumi,
Bounce on the front bumper to see if you can duplicate the noise. When I developed a squeak, it was my torsion bar bushings or lack there of so it was metal to metal rubbing. Swapped to new and squeak went away. WIWIT, I also upted to the thicker 87-89 Sway bar and bushing set. Also new ball joints.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
disband
that appears to be missing the part that stabilizes the bushing and is used to lock in camber settings during an alignment. see the two threaded bolt holes just beyond the strut tower in your photo. that's where the back side of the plate would mount with another single treaded anchor spot in front of the tower.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
disband
here is the OE unit in the catalog with the part in the exploded view.
1978 Porsche 911 SC Coupe - Suspension, Shocks & Springs - Page 2
It looks like someone may have repaired the shock mount and covered their work with goop.
The adjustment clamps should be visible and not have the goop. Just the shock tower itself. You need to clean all that off too se what is there.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Burnin' Rubber
I'll have a goop scrape session and take off the wheel on put her up on stands.
When I push down on the fender, she groans and squeaks bad. If I drive by you, you'll hear loud intermittent short squeaking. The car is not happy at all |
Burnin' Rubber
Thank you for the kind responses. I'll update my observations etc shortly. The suggestions and tips thus far have been VERY helpful
newb.
just run over to TLG and let them get it sorted.
keith '75 RS/RSR-look | '73 CB750 | '70 TD250B r gruppe #436 |
