Burnin' Rubber
Koizumi's Avatar
Front Shock Tower Mount Rupture Help
After a very mildly spirited drive, the front passenger strut started squeaking. So I pull back the carpet to find this:
The squeaks are much much worse after a few miles heading back home. Incessant, constant, loud squeaking
What is the best way to repair this? Are there reinforcement plates that can be bolted or welded in? It's hard for me to tell because of the black goop but is this a very serious rupture?
Old 06-07-2015, 02:19 AM
rupture? are you talking about the crack in the black goo?
looks normal from here. for the squeak, might be the torsion bar rubbing
the inside of the control arm- also check the sway bar bushings
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 06-07-2015, 03:40 AM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
^^^ That shock tower looks normal.
You have some worn bushings somewhere else in the suspension..probably the anti-sway bar as jason suggest.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 06-07-2015, 08:03 AM
RETIRED
Joe Bob's Avatar
Could be bushings as mentioned or a failed strut. Take it to an alignment/suspension shop for a diagnosis.
2012 ML350 3.0 Turbo Diesel
Old 06-07-2015, 09:16 AM
Going to suggest that that car has probably never had an alignment and by now, your rubber bushings are probably shot. The important ones are the control arm bushings and the spring plate bushings.
I'd suggest taking it to a 911-knowledgeable shop and having all that stuff refreshed. Maybe new shocks/strut inserts, too.
JR
Old 06-07-2015, 09:43 AM
Reiver
Reiver's Avatar
To satisfy your curiosity peel back the goo a bit so you can see the solid underbody....
Remove the tire and jack it up...support it properly and move things around a bit to find you squeak....if it is that prevalent shouldn't take much.
De Oppresso Liber
Strength and Honor 5th Legion
Old 06-07-2015, 10:18 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Koizumi,
Bounce on the front bumper to see if you can duplicate the noise.
When I developed a squeak, it was my torsion bar bushings or lack there of so it was metal to metal rubbing. Swapped to new and squeak went away. WIWIT, I also upted to the thicker 87-89 Sway bar and bushing set. Also new ball joints.
'85 Carrera Targa
PCA/POC
Old 06-07-2015, 10:42 AM
disband
juanbenae's Avatar
that appears to be missing the part that stabilizes the bushing and is used to lock in camber settings during an alignment. see the two threaded bolt holes just beyond the strut tower in your photo. that's where the back side of the plate would mount with another single treaded anchor spot in front of the tower.
Old 06-07-2015, 10:49 AM
disband
juanbenae's Avatar
here is the OE unit in the catalog with the part in the exploded view.
1978 Porsche 911 SC Coupe - Suspension, Shocks & Springs - Page 2
Old 06-07-2015, 10:55 AM
It looks like someone may have repaired the shock mount and covered their work with goop.
The adjustment clamps should be visible and not have the goop. Just the shock tower itself.
You need to clean all that off too se what is there.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 06-07-2015, 01:15 PM
Burnin' Rubber
Koizumi's Avatar
I'll have a goop scrape session and take off the wheel on put her up on stands.
When I push down on the fender, she groans and squeaks bad. If I drive by you, you'll hear loud intermittent short squeaking. The car is not happy at all
Old 06-07-2015, 01:31 PM
Burnin' Rubber
Koizumi's Avatar
Thank you for the kind responses. I'll update my observations etc shortly. The suggestions and tips thus far have been VERY helpful
Old 06-07-2015, 01:33 PM
newb.
eimkeith's Avatar
just run over to TLG and let them get it sorted.
keith
'75 RS/RSR-look | '73 CB750 | '70 TD250B
r gruppe #436
Old 06-07-2015, 01:59 PM
