Jhogan0101's Avatar
Rust everywhere and how to deal with it?
All of my zinc plate metal has a white coating of rust.
Does anyone have anytips for removing it?
I was planing on replating.
Oh and plastic car bubbles are BAD BAD BAD.
Old 06-13-2015, 03:39 AM
Sandblast
Old 06-13-2015, 04:36 AM
VFR750's Avatar
The white power is the zinc selectively corroding to save the steel underneath. So it's doing it's job.
The replating process requires a chemical strip of the steel rust. That also easily strips off the zinc plating. Just try any liquid rust remover. Strips off the zinc too.
Whoever does the replating will take care of the previous coating. They just want it clean. No oil, grease, dirt.
If there is a lot of orange rusty scale, then yes, grit blast away to remove it. You may decide it's not worth replating when you are done.
Old 06-13-2015, 04:45 AM
irl irl is offline
irl's Avatar
Send a message via AIM to irl
Post some shots so we can help better
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 06-13-2015, 08:08 AM
Jhogan0101's Avatar
Ok ill get some pics today. Thank you for the info!
82' 911SC Targa
Old 06-13-2015, 09:15 AM
Hello jargon. Regarding the car bubble, are you talking about the bag or the inflatable approach. If the bag, did the reccommended desiccant not work? Please share your thoughts behind the "bad bad bad." Thanks.
Old 06-13-2015, 11:49 AM
Jhogan0101's Avatar
Here are some pics of the disaster
82' 911SC Targa
Old 06-13-2015, 02:37 PM
irl irl is offline
irl's Avatar
The white dusting and the surface corrosion on the hood lock is simple and can be wire brushed off. The rust on the Door I am very concerned for you. It is very extensive and you are on seeing the tip of the iceberg. The lower jacking point may be completely gone. If this car is driven regularly just tackle on area at a time. Do not start tearing everything apart or it will take you a year to get it all back together. Start pulling some pieces apart, clean them, replace some and keep going. The door area is going to need some metal fabrication and welding. A very common area if you seach jacking point rust on here.
79 SC unmolested
25 GTS
Old 06-13-2015, 03:59 PM
Wow! That car looks like it have been in a flood. Never seen corrosion distributed like that.
Marv Evans
'69 911E
Old 06-13-2015, 10:37 PM
I see rocker box replacement in your future. Looks like a car that has never seen the inside of a garage.
Bob B
Old 06-14-2015, 12:47 AM
TheSt|G's Avatar
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 06-14-2015, 05:35 AM
Jhogan0101's Avatar
Boom. Lol
Yeah im not very optimistic right now.
I will be stripping her down to the chassis.
I think i will try the ultrasonic cleaner (8 gal) route for most of the components.
I was away for work and my dad put her in a plastic bubble outside for a couple years thinking it would be protected and instead aged the car like 30 years.
82' 911SC Targa
Old 06-14-2015, 07:01 AM
stormcrow's Avatar
As Marv said either that car was in a flood or kept for years in a very damp place. Anyway there is a product called rust converter that will stop the reus and can be painted over. You need to clean the scale off first.
However I would recommend the entire body be soda blasted and primed and prepped. Too much rust not to take the farm down and do it properly.
SteveKJR
Proud Owner of a 78 911 SC Targa
"A Porsche does more then just go fast in a straight line"
Old 06-14-2015, 08:15 AM
Concestor0's Avatar
I'm sorry to see your car like that, hopefully the rust is still at the superficial stage and can just be blasted clean. You may also want to look for assistance on the Paint and Bodywork forum.
1986 Porsche 911 Coupe
Old 06-14-2015, 03:11 PM
irl irl is offline
irl's Avatar
It's not a flood car, it's an east coast car.
79 SC unmolested
25 GTS
Old 06-14-2015, 03:37 PM
Das Schnell Ei's Avatar
soda blaster with a medium cut on 70psi will take off the scale and most of that nasty stuff in the engine bay...then hose it out with water... the part on the door jamb is the big issue
'77 911S Coupe 3.2 Turbo
'76 911S Coupe 3.0 964 cams...no sunroof
'75 911S Cabbie 3.2 SS Web cams & 46mm Webers
'73 914 1.7 Webers & Header ... sold
'74 VW 1303S 1600cc DP Web 110 & Solex
Old 06-14-2015, 03:41 PM
TheSt|G's Avatar
Originally Posted by Jhogan0101 View Post
Boom. Lol
Yeah, at this point, you will really need to strip the chassis to the bare metal. As the expression goes, that's just the rust you can see.
Tell your dad that salt is used for preserving meat, not cars.
Old 06-15-2015, 05:04 AM
Jhogan0101's Avatar
Behind rusted door latch area.
82' 911SC Targa
Old 06-17-2015, 03:41 PM
I've never seen a lift like that, odd.
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end.
http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html
Old 06-18-2015, 09:09 AM
