This is contrary to bald-face fabricated crap to undermine Charlie Griffith. Here is a tid-bit from 2013 Quote:
http://forums.pelicanparts.com/porsche-911-technical-forum/763046-3-6-c-upgrade-10.html#post7583362 |
No, I don't know why Charlie uses this method with this car. In stead of inventing some stupid schitt and having a wild fantasy about how wrong Charlie is, why not just ASK HIM? |
Posed as questions...? How does one explain sub-freezing vent temperatures when you have 2 separate control systems that if not somehow over-ridden should prevent same? |
Yes, you do often pretend to know stuff you don't. The reason that sub-freezing vent temps are possible has been explained to you on more than one occasion. I found those explanations to be plausible, and your continued harping on the subject is abuse of your posting privileges. The fact that YOU don't find the explanations plausible is meaningless. Your lack of knowledge and inability to think past your dislike for Griff is evident, always. |
I don't know. This is.a tough decision... Becks or a Martini, 3 wood or lay up. OMG!
Dennis |
When people who give a remote shiet vomit all over their laps and want to place a dagger in his heart, he responds to push back with rhetoric. wwest is the quintessential "C" word. He's got nothing except hate for CG. Eff you, wwest. Eff off and die. I'll take a vacation for this. Eff that a-hole. Moderators and their bosses, including Wayne, should be horse-whipped for allowing this cancer to propagate. Make sure you keep the ban to just a few days to be fair, like you do with wwest. Like maybe a minute. Eff it, ban me forever. I'll find another place. This is a God damned joke. I think I have made my point. Get rid of this troll or get rid of me. |
NathanR, thanks for an interesting thread detailing a worthwhile effort. As always seems to be the case on this subject, it has deteriorated into banality and name calling. I, for one, am going to unsubscribe and quit watching the train wreck.
Thanks again for your effort and everyone who has had positive, constructive input! |
A handful of people stand up to this imbecile. Not you, though. |
Let me get my sand pole, errrrr wedge, at the ready!!! PS - speaking of "in the hole", Bob nailed it!!! |
But I have a solution. The solution is that when Willard posts stuff that's off-topic, report him for abuse, don't answer back, and make a post suggesting that if he wants to change the subject, that he start a new thread (instead of crapping up the other threads with his bovine excrement. In addition, that moves his troll meter to the left significantly. And shortens these threads to a more helpful length. No matter how hard he trolls you, just suggest he start his own thread. That's it. |
Dude, I am furious. This forum is pathetic in it's oversight. Give me some space. |
Besides, the lowest, high temp in the local, seven day forecast is 104, with Sunday's and Monday's highs predicted to be 106 (lows all week in the mid-80s); dat's gotta take a tole on the ole' noggin, right?!?! |
"evaporator + freeze" "evaporator + ice" Some responses go all the way back to 1999. All I have found so far is suggested or methods used to prevent freeze up of evaporator is inadvertently or intentionally operating sub-32dF.... 1. Turn the cooling down.. 2. Recalibrate the thermostat. 3. Change the thermostat's hysteresis (on/off span) 4. clean/burnish the capillary tube. 5. Makes sure the capillary tube is in contact, actual or some medium, with the brass sleeve. 6. Make sure the brass sleeve is in.... 7. Relocate the capillary tube. One thread stands out as most needing an answer... http://forums.pelicanparts.com/porsche-911-technical-forum/858116-c-reverse-gases-early-model-911s.html |
Why not put that gobble-de-gook in the thread YOU created on that very subject, rather than in Nathan's thread on his a/c system upgrades? http://forums.pelicanparts.com/porsche-911-technical-forum/837717-sub-freezing-vent-temps-how.html |
Status update on my project. I sprung a fuel line leak while making my victory lap, new hose ordered from or host, due in on Monday. Once every thing is put back together I will check pressure, and perhaps reduce some of the charge using CG's recommended hi side pressure calculations.
With any luck, I will be able to run a track day at ORP on the 16th, and be cool as a cucumber on the drive over. |
System is all RetroAire as I have stated before. Dennis |
Update.
After working well for several weeks, including the aforementioned long road trip to ORP, today my system pooped out. Driving home w. OAT ~95F, I might have been getting 75F vent temps. A few hours later w. Car finally in garage, was able to throw my gauges on. W. 85f OAT, was able to get vent temp ~72. Static pressure ~90 psi, engine was hot. I let a little freon out until high side approximated Charlie's formula value, 215 psi http://forums.pelicanparts.com/uploa...1440560479.jpg |
Airflow from cabin vents was good. All the condenser fans seemed to be operating.
Suction line connection to compressor was not cold. When I have time, I'm going to pull up the floor board to see if the underside of the evaporator is clogged. That's all I can think of at this point. Any thoughts? |
No way you picked up a giant flying squirrel that attached to the bottom of you evap within one road trip. Stumped. Let's assume, for discussion, your evap froze solid, for grins. How much time between driving and pressure testing occurred? |
Agreed with Bro Bobasaurusrex, pressures look more or less perfect. Hard to explain the poor vent temperatures and a plugged evaporator doesn't seem likely since the vent airflow is strong - really strange.
Just to clarify, the pressures in the above pic are with the compressor clutch engaged and the compressor running, correct (not static pressure)? And if so, is the engine lid down? |
1) With the system 'operating' go to your smugglers box. Inspect the evaporator outlet pipe. Is it frozen, sweating or warm. Inspect the expansion valve inlet hose fitting, is it cold, cool or warm. 2) If you have a digital thermometer with a decent length probe, drill a small hole for it in the top of the evaporator box near the thermostat's probe, preferably drill this hole closer to the evaporator blower motor's plastic vertical housing or toward the rear of the box near heading toward the windshield (anywhere away from the probe but where there is a sufficient area of evaporator cooling fins for it to be inserted into), and take a temperature reading of the evaporator coil when the system is operating. |
Yesterday was filled with scheduled fun so I didn't get to think or do anything related to this issue.
After I provide some clarification, I'm off to the garage to investigate further. I started my drive with the car pretty hot and the AC never even got cool. I was not able to check things out until about three hours after the event. Btw, relative humidity at my location was probably less than 20% Yes, the compressor was running and the deck lid was closed when I observed the pressures posted above. Yes, gauge picture was at that time. Personally my bet is on the flying squirrel, or, in this case, crappy foam insulation I used on the outside of the evaporator box. Who knows, we'll see. To get into the smugglers box, I have to disconnect an amp, which is a PITA. May not have time for that tonight, but will over the weekend. Question, what if I inserted a thermometer probe into the capillary tube hole (after removing said tube) ? Don't have a skinny enough probe but might be able to borrow one. Thanks everyone. Nathan |
Report:
No flying squirrels. Bottom of Evaporator was fine. Before yanking amp, went for test drive. Fan speed = 4, thermostat fully CW. Amb. T = 83. In the first 3 blocks vent T dropped to 72. I lowered fan speed to 3 and vent temp dropped to 68. Turned fan back up to 4 and vent temp went up to 72 and kept rising to 75 Pulled into garage and turned fan speed to 2 (lowest on speed) and temp dropped to 58. Shut off car, spent 10 minutes pulling amp and opening smugglers box. Turned car back on for a few minutes. Evap outlet line cool, not cold. Could the the txv be not working right? I still have the original Evap and txv assy sitting on the bench, could reinstall this weekend. |
While testing in Tuesday night, the compressor ran the whole time as far as I noticed
I'll try the temp probe insertion tomorrow night
As I speculated in post 228, I did in fact drive to ORP and back on the 16 and the 17 th. AC worked well for the 5 hour drive. The last couple hours on the way out I was driving into the sun and had to toggle between max fan and medium (settings 4 and 3) to stay comfy. On The way back, settings 2 and 3 were adequate
ORP was a blast, btw. Highly recommended for you in the PNW.
| All times are GMT -8. The time now is 08:55 PM. |
