engine bay cavity behind strut tower
Both of my openings behind the strut towers are open. I am looking for something to plug them up that will not burn. Any suggestions?
If you must, you could simply order the two foam blocks that were there from the factory.. they're still available.
RGruppe #180 So many cars.. so little time!! |
Still here
Funny, I was just wondering about that foam block on the driver's side of my car. Passenger's side is gone.
onboost, running down the hot asphalt in Phoenix, I can imagine the engine fan sucking hot superheated air from the street across my exhaust up into the engine compartment. Do you know of a place to order online or just dealer item? Thank you for the info.
Member 911 Anonymous
If you don't mind not being concours, you can use HVAC or water heater foam insulation. That round foam that surrounds the water pipes.
Use some 3M adhesive and shove it in there. Problem solved
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Draco, I don't mind at all, that sounds like a plan, thanks
Remember do not completely seal it, just make sure it is about the same length as the remaining OEM. Apparently PAG wanted some air to circulate back there. :-/
From our host, 911 504 930 00 OEM $17.75 2 reqd.
If these are missing on my car (I will have to look), could that explain why I am getting heat/warmth in the cabin with the heat off? It definitely feels like the heat is coming from behind me.
Here is a link to an old Pelican thread on this blocking off this area. Hot engine bay- Can someone measure the length of the a new block? Any pics of these install or installation pics so I know where to put these (if mine are missing). Thanks
Who, What, When, Where, Why and How. |
93Nav,
Most likely your flapper box is stuck open or not closing all the way when levers are down. Jack her up safely and have a helper work the levers, I bet you will find your culprit. If your rear seat belt bolts are missing, it may be seeping hot air throw those.
Thanks for the replies. I will check the flappers.
