What is this connector and how do you disconnect?
![]() If you are looking at the engine from the back it is the drivers side towards the front of the car. Looks like it is a fuel supply to the fuel lines? (Black rubber tube to metal nut)
82' 911SC Targa |
ROW '78 911 Targa
On the rubber hose side there Should be a 12mm(?) hex area for a wrench on the smaller side of the fitting right up close to the larger flared fitting nut.
Unless someone rounded it off for you! Then you are looking for vice grips...
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 06-18-2015 at 03:11 PM.. |
Think that might come off your charcoal canister. The other end connects to a vent line coming from the fuel tank for emission purposes. That is if you are referring to the line with the male end showing with no hose connected to it.
SteveKJR Proud Owner of a 78 911 SC Targa "A Porsche does more then just go fast in a straight line" Last edited by stormcrow; 06-21-2015 at 05:53 PM.. |
Fleabit peanut monkey
Also, the "other end" is a smaller diameter hose that runs to the center tunnel from the charcoal canister, through the tunnel metal tube, reconnected to the little fiber wrapped hose, up to the expansion tank via the fender wall, back into the frunk and finally mates with the gas tank.
1981 911SC Targa Last edited by Bob Kontak; 06-21-2015 at 06:34 PM.. |
ROW '78 911 Targa
I assumed he was talking about how to get the fuel line mounted to the intake runner apart,
seeing as he asked how to disconnect it...
You are correct, Sir. That is what OP inquired about.
1981 911SC Targa |
