Question Thanks again to Beep Beep and a question; 930 decel
I just want to thank beep beep again for his very informative post on the BOV gaskets and recommendation to replace. I replaced (or installed!) 1 , but the other one was fine. I also adjusted my throttle, as I was getting maybe 1/3 of it! There is definitely more power now! After replacing the gaskets and going for a ride, my idle was noticably higher. I turned it down twice and it seems to have stabilized now. However, sometimes when downshifting or approaching a stop, now the idle hangs between 2-3000 RPM. Is this due to the decel valve? If so, why would this missing BOV gasket cause this, or is this a throttle adjustment issue? If I hit the throttle, in neutral, or with clutch in, I can get the idle to come down, although pretty slowly. I know there have been posts about removing the decel valve. I have contemplated this, but am not sure of the best way to do this. Perhaps someone could elaborate.
Thanks!
2009 997.2 C2S
Old 11-11-2002, 07:55 AM
Your hanging idle could be cause by a bad decel valve, or something else. You have to eliminate the valve to see if it is bad.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 11-11-2002, 02:52 PM
beepbeep's Avatar
I'm glad to see that my expirience helped someone else. Leaky BOV-gaskets usually contribute to sluggish boost buildup and bad idle.
Speaking about your issue with hanging throttle, it can be also caused by throttle cable itself, friction on a butterfly-valve or faulty deccel-valve. Altough it's possible that bad decell-valve is causing your problems i would look to other possibilities first, as it seems like you started expiriencing these problems after throttle-adjustment.
You can easily check this by taking of the thin hose off the front side of decell-valve and plugging it, thus rendering it inoperable.
Also, check all small hoses for eventually leak. There is a slight possibility that high idle is caused by BOV-piston getting stuck or not moving far enough. There is quite complicated vacuum-system for pulling BOV-piston composed of thin hoses. Any leak there could prevent piston from moving correctly.
With other words: there are three "sticking" things:
1. Throttle
2. Decell-valve
3. BOV-piston
Troubleshoot them one by one and see which one is making problems.
If idle is falling down slowly then i tend to believe it's deccel-valve.
Good luck!
Thank you for your time,
Old 11-11-2002, 03:27 PM
Thanks for the replies. I will try the blocking the decel valve hose first.
2009 997.2 C2S
Old 11-12-2002, 06:21 AM
