oh snap's Avatar
Any good tricks to remove the front spindle spacer ring?
I tried a cheap 2 jaw gear puller but there is very little of the ring to grab on to, especially at the bottom. I filed down the puller to try to get a better grip but no good.
What has worked for you?
#24 in the pic
1985 Iris Blue M491 911 Coupe
Old 06-19-2015, 09:17 PM
Cory M's Avatar
If you aren't reusing it you can easily push it off with an air chisel with a pointed tip, just stay on the lip and don't hit the spindle.
Old 06-19-2015, 09:26 PM
Heat them up with a propane torch and they come right off. Don't forget to replace the O-ring behind it.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-19-2015, 10:39 PM
Almost Banned Once
sc_rufctr's Avatar
Light Hammer and a bronze punch... Gently, light taps only.
Clean up the area first so you can see what you're doing.
- Peter
Old 06-19-2015, 10:41 PM
oh snap's Avatar
Planning on reusing them as long as I can get them off without too much trouble. Will try some heat and a punch in the morning. Thanks all
Old 06-20-2015, 03:07 AM
non-whiner
mreid's Avatar
I would not try and reuse them. They are not expensive and easy to ding up when removing. Heat is the secret.
"Too much is just enough."
Old 06-20-2015, 05:28 AM
