911buff
decceration stalling issues
My '71 T with Zeniths and a Bosch dizzy wants to stall when I come to a stop. it will immediately restart and idle as designed. I adjusted the idle circuit (1/4 turn richer) but no change. It is more pronounced when coming to a hard stop. If I slow down at a gradual pace, it will stay running but the idle is low and then comes up to ~900 RPMs. Any ideas?
'71 914 1.7 - sold, '70 914-6 - sold (I am such an idiot!), '73 914 2.0 - sold, '74 914 2.0 - sold, '74 914 2.0 - sold, '67 911 - sold (Again, I am an idiot), '91 C2 - sold |
Does it do it when you come to a stop out of gear but braking hard? If so suspect the float levels allowing fuel to slop into the intakes on braking. If you are downshifting through the gears then its probably vacuum related, high intake vacuum causing to much advance/retard
1972 911T Coupe with a '73E MFI engine and 'S' pistons 10 year resto mostly completed, in original Albert Blue. ***If only I didn't know now what I didn't know then*** |
911buff
It does it out of gear. That gives me something to check. Thank you!
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
I have the same issue periodically on a 81' 930. Obviously we have totally different fuel systems with same issue. The part that sucks is it doesn't do it all the time, but usually when the car has been sitting a few days. Even then, it is kind of periodic and tough to diagnose. Some stop lights it will stall, others its fine. After complete warmup the problem goes away. Is this similar to yours? I have my deceleration valve removed, but if that was the problem I would suspect issues all the time.
81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... |
