Kolibri
Hello folks. Wrapping the final bits of my 69 911T coupe. I am stumped now.
The INNER window felt which clearly must be glued in place. I have searched hi and lo for a picture of how this is supposed to fit. Before I start a gluin', I want to see a picture of how it sits. I even have original factory manuals and they just mention placing them in. Without a reference, I can screw the pooch and have to tear it out and start over. This picture shows how I 'think' It should glue in. Just a smidgen above the rail top, with the narrow end down into the slit of the window track and the large end up top. There appears to be little humps in the window frame which would set the height of this seal, but i was hoping one of you had a nice shot of this before I tackle it. ![]()
1942 VW Kübelwagen 1940 Zündapp KS 600 1941 Zündapp KS 750 1975 Volvo C303 TGBII 1967 Honda S90, 1975 CB550 |
It should have several metal tits on it that pop into holes in the door lip. Maybe aftermarket cheaped out and expects you to use glue. The factory ones are not cheap.
Kolibri
Not the outer door. That's got the tits..
![]() The inner track, towards the passenger compartment
Kolibri
These are factory parts. I think I have it. When you place the arm rest "garnish" it lines up ok. Just needs that clean look
It seats with metal clips on the interior lip with v section rubber towards the glass. Unless the Targa is different, the re There is no outer. The outer seal slides on the door trim.
Doesn't look right to me, do you have a picture of the seals off the car?
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Thread Tools | |
Rate This Thread | |
