Hi all, just wondering if anyone has a way of doing up the injection manifold nut on cyl-6, the one closest to the centre of the car. I've tried a few different spanners sockets etc, still takes me about 40 minutes.:
On what? A Datsun model 1961 bumble bee?
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Funny or silly response hard to say
,its 6cyl,its FI,and its a 911 tech forum.....any more needed,no need for negitive stuff on here.Good luck to the OP getting a sensible answer
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
What year engine? CIS? Usually a quarter inch drive extension with a swivel connector works for me.
Brew Master
On my 3.2 I used a short allen socket with a swivel. These don't require a lot of torque (13 ft lbs IIIRC) Mine are barrel nuts. You say you used a spanner of some sort which would indicate to me yours are not. If you have hex nuts on the manifold, just get a crows foot wrench to fit.
12mm "s" Type wrench.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
You got 16 posts, we don't know what kind of car you have other than a 911, but what year? They are different.
On both my SC and Carrera, one of these will work: 1. An allen socket, on a swivel or a wobble extension, 2. An allen socket that has a ball end. Best of luck.
Flex sockets........
These are the sockets I use for hard to reach fasteners specially the ones for the intake runners. These are 3/8" drive sockets and the 1/4"-drive would work too. ![]() Tony |
Tony, will a regular 12mm socket on a swivel adapter do the job too?
These sockets are used a lot during an engine assembly and disassembly. The ability to reach those fasteners in odd locations makes the job easy and fun. Keep an assortment of special tools and you will enjoy the work with gusto. Tony |
Cool thanks for the advice. I'll grab a 12mm one of those.
I want to do my injector seals so if the sleeve pulls out I was planning to pull the runner if possible so I'm not dropping anything into the intake especially if I have to dremel the stakes down. G. |
