H4 euro lense
will a h4 euro lense fit on my 1977 911 without the anything else needed? Also my lights are not the brightest so want bulb can I get as well?
Thanks Sam |
ROW '78 911 Targa
Do you have H4 lamp assemblies on your car?
Post a photo.
No, the H4 lens, by itself, will not fit as a bolt-on replacement to a US 1977 911. The H4 system is a complete bolt-in unit. You have to remove the US sealed-beam unit, complete with its mount, and replace it with the H4. The H4 fits a 55W or 100W bulb.
Also, the H4 euro lens is asymmetric, providing light angled up on the right side. The later H4 for US lens is not asymmetric. |
you can, however, replace your 7" sealed beam bulb assembly with a 7" round h4 bulb assembly (our host doesn't seem to sell the e-code hellas any more? -- see, e.g. Amazon.com: HELLA 002395991 7" H4 Type Single High/Low Beam Headlamp: Automotive) they gave me FAR better light than my 7" sealed beams did, but only cost a fraction the 911-specifc housings -- be sure to buy a headlight relay from our hosts -- I've been happy with high (80/100w) wattage bulbs.
Thanks for the info that helps. If I wanted the Euro style look i would need the whole assembly. any recommendations on where to get it? Also my other ring is blue.
Sam |
Our host sell them -- 1986 Porsche 911 Carrera Targa - Lights and Lenses - Page 3
Note the other parts you need for EACH headlight : Also use (Qty.) (1) 900 631 103 90 bulb, (1) H-4 Bulb, If updating to painted headlight rim, also use (Qty.) (1) 911 631 141 00 rim, (1) 911 631 033 00 screw, (1) 911 631 132 00 screw. You'd either need to get the paintable headlight rims above and get them painted to match, or enjoy the chrome rims that come with the headlights linked above (and that the paintable trim rings cover up) |
John 1972 911T 3.0L Coupe 1986 Carrera Targa 1989 BMW M3 2007 328iT |
Rescuer of old cars
The sealed beam sockets are the same as H4 sockets, no socket change is needed for a '77.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
