Rennch on YouTube
Scott, they are Accumoto 15 X 9 & 11, with Avon Historic Slicks and the original Porsche Vintage Racing Pattern hand carved by some craftsman over at Roger Kraus.
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
Rennch on YouTube
Decisions, Decisions
So, I've been doing research for days on what parts to get where, and here's where I've landed so far. If you see any room for improvement, let me know.
Flywheel - Patrick Motorsports (sounds like that's where everyone gets it) - $370 Clutch - Unknown if needed. Engine Crossbar and Cradle - Sourcing 3.0/3.2 from Pelican. Will raise engine to same level as 3.0. Engine Tin - Sourcing 3.0/3.2 from Pelican Camshaft/Power Steering Block off Plate - Patrick - $75 Oil Pressure Sending Unit - Pelican Cone Air Filter - Timmons - $195 Transmission Studs - ? Pelican or Timmons Oil Feed Pipe (instead of external cooler) - Timmons (Patrick's is very $$) - $145 (any other options?) Accelerator Cable - Patrick or Jae Lee custom. - $290 - (Timmons is too flimsy) Single Pulley Conversion - Timmons - $139 (vs. $385 at Patrick) Ignition Coil Mount - Patrick or Jae Lee Custom - $120 Wiring Harness Conversion - Timmons or Custom (Timmy2) $184 (vs. $395 Patrick) Oil Crossover Pipe to thermostat - Pelican Oil Crossover Pipe from Engine - Pelican Headers - Using 993 OEM headers Muffler - Looking for Sport muffler AC Bracket Removal - Custom
Rennch on YouTube
Was in Portland for a conference, manage see a vintage race at PIR, and stopped by the Rothsport racing facilities. Jeff, Carl, Earl, Scott and the others have put together such an unbelievably first class facility. It's just eye candy everywhere.
I picked up a few bits for my conversion. Oil tube extension, single pulley conversion, power steering block off plate, and a couple other juicy bits. ![]() The bad news? Turns out I can't use my current transmission (7:3:1 mag case from a 72 911). So, I'm now in the market for a 915 from 82-86. Drag. Sent from my iPhone using Tapatalk
Rennch on YouTube
Pure eye candy from Rothsport.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk
seems you enjoyed your stay in Portland! Great timing catching the vintage at PIR too. Congrats!
1984 911 Carrera Coupe - 32C #73 - M64/05 1998 E36 M3 4dr 2006 Sienna 5dr - the hauler 2004 Lexus GX470 2010 Cannondale Caffeine II - Lefty |
But the 7:31 R&P is too weak for a 3.6. I'm fitting a G50 into my -69 and that is a proper head ache....
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Under the radar
Excuse my ignorance, but have you considered installing an engine mounted oil cooler? Is that a viable option?
Great build. Makes me wish I was still in SD.
Rennch on YouTube
Still looking to source 3.2 engine tin and crossbar/console
Congrats with your 3.6 project.
One day, I would love to do the same. |
Rennch on YouTube
UPDATE: sorry it's been forever since I have updated this thread. There's been a LOT of parts collecting.
This week I've been working on mounting my first oil cooler. I will have one of the fender, and one in the front bumper. Below are pictures of fabricating brackets for the fender mounted oil cooler. ![]() I do use cardboard to mock up, and 1 inch flat steel to make the brackets. I'll put 90 degree outlets on the cooler and run the bumper mounted one inline. ![]() Here are the brackets, pre paint. ![]() Using high temp engine enamel. ![]() Painted and installed. Tomorrow I'll work on fabbing the rx7 cooler in the front. ![]() ![]() ![]() ![]() It's SUPER solid. Very excited about it. Sent from my iPhone using Tapatalk
Brando
It's fun making functional important mods. That one looks good too. Make sure to block off as the factory did. You'll need it and a fan too.
Turbo powa! 1977 911s. it's cool |
Rennch on YouTube
How did the factory block it off?
Brando
Here is a picture of how they do it but your cooler is custom so you'll need to make some sheet metal block off to fit your application. Should be a tight seal from both sides of the cooler. You don't want air to choose simplest path because that's not through the cooler, it's around it.
http://www.pelicanparts.com/catalog/images/oil_circ/lower_stone_guard.JPG
Rennch on YouTube
I've got a separate thread on wiring the 1995 motor into my 1969 Chassis as well: Wiring 3.6 into 69 911 Help
Rennch on YouTube
Question for you experts. My plan is to run the Setrab in the fender, then an RX7 Cooler in the front. Do you think the RX7 Cooler is necessary? Or will the Setrab do ok? Sea Level car, not a track car. (Autocrossed)
Brando
You're doing away with one cooler already. One with a fan. I promise you need two. And you'll want to put a fan in the fender one. I think you'll be fine with two. If you went to Vegas there would be no doubt you'll want at least two. I've gone through this with a turbo in Vegas but even in cool weather it was clear the second fender cooler was wanted.
Rennch on YouTube
So you're suggesting to do another fender vs the front rx7? I have the bumper for it, and it's already been modded.
Brando
No, front cooler is fine.
Actually it's better.
