Finding very slow AC leak
Gentlemen and Ladies,
I just got the car out of storage, did its annual maintenance and found, to my chagrin, for the second year running, that the AC system was operating poorly, vent temperatures on the order of 60F, way worse than the 35F I have typically seen. The system is a Retroaire and has worked well in general, but last year I had the same issue except for the system was completely empty of refrigerant. I (last year) went and checked for visual leaks, found a very small amount of residue on the suction side of the compressor fitting, tightened the fitting as far as I dared and was able to draw and maintain vacuum. All good, or so I thought. I recharged the system, had a good year with AC in last year's driving system and fully expected that all would be well....but, alas....no. There is sufficient residual pressure in the system so that the compressor kicks in and provides some cooling, just not enough. I have checked all the fittings again for any residue of any kind (PAG oil leaks indicating refrigerant leaks), no problems. So, the leak is very slow, taking over a year to lower the pressure this much. How to find it? Any ideas of tackling a leak this slow? Or do I just charge it up and deal with having to put in a can of R134a every year? How about adding sealant to the mix? Don't like the idea, but then again, I don't much like the idea of redoing every fitting, replacing the O rings and perhaps still not addressing the issue. Thanks, Dennis PS - when I installed the system the first time I forgot to mount the Schrader fittings that RetroAire provided. Looks like there is no real way to put them on now unless I evacuate the system....mind you, I also don't know how to do that. I presume I have to take out the little valve assembly on the compressor inlet/outlet and then thread the Schrader's onto those. |
Hi Dennis,
That scenario is fairly common. Shrader valve leaks are pretty common, particularly with old cores. Very easy to change, depending on what adapters/cores you now have. I would recommend evacuating the system, removing the port adapters you have, removing the old cores and installing high quality adapters with new cores. Do not under any circumstances put any sealer in the system. I will probably destroy your system and you or the next owner will need to start over again. Do a search of a/c black death. You may need to have a pro do the charge adapter work, and he may be able to find your leak with electronic detectors, etc. Good luck. Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
You can buy R-134a manifold pressure adaptor/fittings that depress the existing valve stem. Also, you would then have a double valve system at each fitting in case you have a slow leaking R-12 valve. Sounds as if you have fitted a pressure switch, assuming so what is the high pressure compressor cutout PSI ?? Anything more than 325 PSI would be inadviseable. A 12 Oz (net, 8-9 Oz actual) can of R-134a Is an little as $7..... Even if it takes 2-3 cans... |
There is a high pressure switch in the Retroaire system, don't know its settings, but when I hook up the gauge set my pressures were below that and within the tolerances. The issue is you really cannot buy R134a as a consumer here in Canada. Now....it is available through alternate means...so I can definitely manage it. It may turn out to be the best solution. Thanks for your help, I do appreciate it. Dennis |
Issue is finding an AC shop here in Calgary that is willing to do custom work. Most of them take one look at the car, hear that I did the install myself and either quote stupid numbers (yes, we will charge it for $1500, no guarantees) or just tell me (literally) to get off of their property with my stupid little car. No joy likely there, but perhaps I can try again... Thanks for your help, Dennis |
Sorry to hear how difficult it is to find an a.c. shop. It's not that bad to diy. Lots of information here.
Good luck Dave
To find the leak, you need to use an electronic "sniffer". They are not too expensive. I have had one for years and they are super sensitive.You just move the wand head around all the connectors and if even a tiny amount of R134 (R12 or any "halogen" type gas) is present the unit will beep like crazy. I have tested mine by checking in the vicinity of a disconnected guage set after recent use, and it went nuts. Perhaps a Pelican near you may have one you could borrow.
Electronic Freon and Halogen Leak Detector
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 07-01-2015 at 01:08 PM.. |
Be careful. I bought a cheap one and it responded to moisture.
Dave
Please forgive my complete ignorance on this topic, but could you just fill with a nice inert gas like nitrogen and squirt soapy water around all the fittings? (See, I told you I am ignorant on this...).
on tools at pawn shops! Quite a few of my very high quality tools came from a pawn shop, at less than HF prices!
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 07-01-2015 at 02:28 PM.. |
Fleabit peanut monkey
Yes you can and I would like to know hot to set up the fittings to do this.
1981 911SC Targa |
Dye, and a dye light would be helpful here also. Won't really help if it is coming from the service ports though
No left turn un stoned |
Expanding on Bob's comments above -- we did exactly this tracking down a pinhole leak in a vintage home refrigerator -- I believe we fed the nitrogen in through a standard 2 dial AC manifold using "normal" schrader fittings (it's been around 15 years now). interestingly, there's plenty of residual freon still left in the system, so even though it was pressurized with nitrogen, the freon detector still had no trouble finding the leak. A lot cheaper using nitrogen than r12/r134.
There are, however very good electronic leak detectors. Just not that one. Dave
Really db?
Soapy water works fine for a gross leak. For 12 oz. per year, it ain't goin' do it. Sorry, Dave
go to an HVAC parts house and get their soapy water. it works better. has a "sticky" substance in it.
if your evap is leaking you really need a sniffer. i have one. found a leak on my rear condensor and in the line that runs down the left side of the car. leak was just in front of the rear wheel
