Student of the obvious
LeeH's Avatar
Troubleshooting power mirrors
Both of my mirrors quit working at the same time. Best I can tell the fuse is good. It appears the same fuse is used for the heater blower, which still works.
Now what? I assume the next thing to check is the joy stick switch on top of the door. How does that come out?
Any other guidance would be appreciated!
Old 11-13-2002, 08:19 AM
Heck, I’m only 5 not 71!
targa80's Avatar
What about the selector switch that is on the dash. On my 80SC it allows you to select which mirror is to be adjusted.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 11-13-2002, 08:24 AM
Send a message via ICQ to Kurt B Send a message via Yahoo to Kurt B
Glad this came up. Where the wiring goes through the base into the main mirror part, there is a threaded guide through which the wiring goes. This guide holds the two pieces together. It's stripped.
I ordered a new one, but does anyone know how to put the wiring through there? I can't figure out where the wiring is joined into the rest of the loom, and the stuff inside the mirror appears to be soldered...
-kb-
Old 11-13-2002, 09:41 AM
Glasgow 911SC's Avatar
Lee
Not sure if your wiring will be the same as mine but try tracing the purple/black wire from (I think) fuse 14. Check there is continuity from fuse area to joystick. To get to joystick unscrew 2 philips heads that hold door top in place and remove the door top. The loom pulls away from the switch. If there isn't continuity then a broken connection is likely (either wire broke or pulled out of connector block in luggage area where it goes into the wing).
Hope this helps
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 11-13-2002, 10:57 AM
